I’ve been using a more intuitive, fast-moving coding workflow where I follow momentum and ship quickly, but now I’m worried it may be creating hidden technical debt. A few shortcuts that felt efficient at first are starting to cause messy code, harder debugging, and maintenance issues. I need help figuring out whether this kind of workflow can be sustainable and how to keep speed without creating long-term software development problems.
Fast shipping is fine until your change failure rate climbs and lead time gets worse. That is the line.
I use a simple check:
- Do bugs keep coming back in the same area.
- Does each feature touch too many files.
- Do deploys need tribal knowledge.
- Do tests fail for random reasons.
- Do you avoid refactoring because it feels risky.
If you hit 2 or more, debt is building.
Keep the speed. Add guardrails.
- Write a short ADR for shortcuts. 5 mins.
- Add tests around rushed code first.
- Put a time cap on hacks. Example, ‘remove in 2 sprints’.
- Track MTTR, change failure rate, and rollback count.
- Reserve 20 percent of each cycle for cleanup.
I did the ‘move fast’ thing on a SaaS app. Felt great for 3 months. Month 6 was pain. Small edits took 3x longer. Prod bugs doubled. Team morale got rough too.
Vibe coding works for prototyping. For prod, you need intent, not vibes. Fast is fine. Blind is not.
I half-agree with @stellacadente. Debt is not just ‘too many hacks,’ it’s ‘are you freezing future options?’ Sometimes a messy shortcut is cheap debt. Sometimes a ‘clean’ abstraction is prepaying for problems you do not even have yet.
What I’d watch is reversibility.
If your fast-moving workflow creates decisions that are easy to undo, who cares. Ship it. If it hardcodes assumptions into data models, APIs, auth, billing, or infra, that’s the danger zone. Those are the spots where vibe coding gets expensive real fast.
My rule:
- UI mess? usually recoverable
- duplicated service logic? annoying but fixable
- bad schema choices? pain
- hidden coupling between systems? mega pain
- no ownership boundaries? chaos
So I would not slow down everywhere. I’d slow down only at ‘blast radius’ points:
- database schema
- public interfaces
- background jobs
- permissions
- observability
Also, if you cannot explain why a shortcut exists 2 weeks later, that is a smell lol. Momentum is useful, but memory is not architecture.
Vibe coding is awesome for discovery. Terrible for foundations. Thats the split I’d use.
