Need help understanding how the Aavot App works
I recently installed the Aavot App but I’m confused about its main features, setup steps, and how to use it effectively for daily tasks. The app interface isn’t very clear to me and I can’t find a detailed guide or FAQ. Can someone explain what the Aavot App is actually designed for, how to configure it properly, and any tips to get the most out of it?
I installed Aavot a few weeks ago and had the same “what is this doing” reaction. Here is the short version of how it works and how to set it up so it helps with daily tasks instead of getting in your way.
  1. Core idea
    Aavot is a personal task and routine manager.
    Think “to do app” plus “daily planner” plus some light automation.
    You feed it tasks, habits, and recurring stuff.
    It tries to keep your day organized around that.
  2. Main screens
    Names might differ by version, but you usually see:
• Home / Today
Your tasks for today.
This is where you live most of the time.
You can:
– Add a quick task with the big plus button.
– Tap a task to edit time, notes, priority.
– Swipe left or right to complete, snooze, or delete, depending on your settings.
• Tasks / All
Full task list, including future or unscheduled tasks.
Use this for “dumping” new stuff that does not need a date yet.
Then schedule when you have time.
• Routines / Habits
Things you repeat daily, weekly, etc.
Example: “Review inbox at 9am”, “Workout”, “Plan tomorrow”.
Once you set a routine, it auto adds to Today when due.
• Calendar / Schedule
Timeline of your day.
Tasks with times show up here.
You drag tasks to a time slot if the interface supports it.
That turns a vague task into a scheduled one.
  1. First time setup
    What worked for me:
Step 1: Turn off the noise
Go to Settings.
Find Notifications.
Start with:
– Only “due” and “overdue” notifications on.
– Turn off “tips”, “promos”, and similar stuff if that exists.
You can add more alerts later.
Step 2: Add 5 to 10 real tasks
From Today or Tasks, hit the plus.
Add things you plan to do in the next 48 hours, not everything in your brain.
Example:
– Pay rent
– Email manager about report
– Grocery shopping
– Call dentist
– Finish slide deck
Step 3: Create 2 or 3 routines
Go to Routines or Habits.
Add:
– “Plan tomorrow” at night
– “Check Aavot” at a fixed time, so you remember to open it
– One health habit, like “10 min walk”
Step 4: Timebox a few tasks
Open Calendar or the time view.
Give 2 or 3 tasks a start time and maybe a duration.
That gives the app something to organize.
Leave other tasks as “today” with no time if the schedule feels too rigid.
  1. Daily use flow
    This is the routine that made it click for me:
Morning
– Open Aavot Today.
– Mark anything already done.
– Drag top 3 tasks to specific times.
– Snooze or move tasks that you know you will not touch.
During the day
– When a new task pops into your head, dump it in the Tasks list fast.
– Do not over tag or over organize while busy.
– When you start a task, tap it to mark “in progress” if the app has that, or just keep it as “today”.
Evening
– Go to Routines and run “Plan tomorrow”.
– Move unfinished tasks to tomorrow or another date.
– Delete items that no longer matter.
  1. Features that confuse people
• Priorities
Usually three levels like Low, Normal, High.
My rule:
– High: if not done today, tomorrow hurts.
– Normal: standard tasks.
– Low: nice to have, no pain if skipped.
In Today view, sort by priority then time if the app allows sorting.
• Tags or categories
Use few tags, not many.
Examples that helped me:
– Work
– Personal
– Home
– Errands
You tag tasks when you have 10 spare seconds, not while rushing.
• Recurring tasks
For bills, weekly chores, learning sessions.
When you complete it, the next one gets auto scheduled.
Do not create a separate task for each future repeat, always use recurrence.
  1. Using Aavot for daily tasks
Example day setup:
Morning tasks:
– “Review email” at 9:00
– “Top 3 work tasks” at 9:30
– “Quick standup notes” at 10:00
Afternoon:
– “Call client” at 14:00
– “Update tracker” at 16:00
Evening / personal:
– “Workout” at 18:30, routine
– “Plan tomorrow” at 21:00, routine
You then work out of the Today screen and mark each item done.
If something slips, move it to a specific future date, not “someday”, so it resurfaces.
  1. If the interface still feels messy
Try these adjustments if the menus feel confusing:
• Hide advanced views
Many versions have toggles like “show completed”, “show subtasks”, “show overdue on top”.
Turn off everything you do not need.
Keep it to: Overdue, Today, maybe Tomorrow.
• Use light theme or dark theme based on comfort
Sounds trivial, helped me read faster with less eye strain.
• Keep the widget minimal
If there is a home screen widget, configure it to show only Today.
No calendar, no tags.
  1. What to do when stuck
If something is unclear inside the app:
– Check Settings for a “Help” or “Support” entry.
– Look for “tutorial”, “onboarding”, or “reset tips” to replay intro hints.
– Search “Aavot app reddit” or “Aavot app review” and skim screenshots.
– If there is an in app chat or email, send them one short question, like “How do I make a recurring task” so you get a direct step list.
If you post which screen confuses you most or what device you use, people here can walk you through step by step with exact menu names.
Yeah, Aavot is weirdly opaque for an app that’s supposed to “simplify” your day.
@waldgeist already covered the sane, structured approach. I’ll add a different angle: how to strip it down so it behaves like a dumb but reliable checklist, then slowly turn features back on.
1. Ignore half the app at first
Personally, I’d not start with routines and calendar like they suggested. That’s where Aavot feels cluttered and bossy.
For your first few days, pretend Aavot only has:
  • Today / Home
  • All Tasks / Inbox
Everything else is optional noise until you’re comfortable.
Use it like this:
  • Open Today
  • Hit + for anything you must do today only
  • Open All Tasks for stuff you “don’t want to forget but not sure when”
No priorities, no tags, no times. Just raw tasks. Aavot stops being confusing if you refuse to use the “smart” stuff for a bit.
2. Kill the visual clutter
In Settings, look for options similar to:
  • Hide completed items by default
  • Don’t show overdue on top (controversial, but if seeing a red pile stresses you out, flip it off first)
  • Compact view instead of big cards, if available
I actually disagree with starting with lots of overdue and priority indicators like some folks do. If the UI already feels unclear, colored warnings everywhere just look like chaos.
Make the app visually boring. Boring is usable.
3. One tiny rule to keep it useful
Adopt a brutally simple rule:
If you write it in Aavot, you must look at Today at least once per day.
To make that happen, create exactly one recurring task:
  • “Open Aavot & clean up list”
  • Time: whenever you’re usually free for 2 minutes
  • Repeat: daily
That’s the only routine I’d add at the start. Forget workouts, bill reminders, etc. You can move that stuff in later once the base habit is there.
During that daily 2‑minute cleanup:
  • Delete stuff that no longer matters
  • Move anything you didn’t do to Tomorrow or a specific date
  • If something keeps getting moved, either break it into a smaller task or admit you’re never doing it and just remove it
4. When you’re ready, add one advanced feature at a time
Instead of using priorities, tags, calendar, habits all at once, try this sequence:
  1. Due dates only
    • Start assigning “Today” or a specific future date
    • Still no times, no priorities
  2. Then times for only 1 or 2 tasks a day
    • Example: “Call doctor at 3:00”
    • Avoid scheduling 12 things. That’s how these apps become guilt machines.
  3. Then routines for boring repeats
    • Pay rent, take medicine, weekly cleaning
    • If you see 20 recurring tasks flood Today, you went too far, trim back
If any feature makes your screen feel crowded or you start ignoring it, switch that feature off again. Aavot works best when it’s slightly underused, not maxed out.
5. A quick “daily driving” pattern
Once you’re past the first week, a super light flow that works:
  • Morning:
    • Open Today
    • Pick 3 tasks that actually matter
    • Optional: give just those three a time
  • During the day:
    • Any new idea: toss it into All Tasks/Inbiox, no extras
    • Do not try to fully organize mid‑chaos
  • Evening:
    • Run your “Open Aavot & clean up list” task
    • Move leftovers to tomorrow or a real date
    • Nuke anything you already know you’ll ignore
If you post a screenshot of the view that feels most confusing (blur any private info), people here can usually say “flip off this toggle, hide that panel, and it’ll look 10x cleaner.” Aavot can be good, but only after you bully it into being simple first.
Short version: think of Aavot as three different “modes” of using the same app. Pick one mode and ignore the rest until you’re comfortable.
1. Three practical “modes” of using Aavot
Instead of features, think in use-cases:
Mode A: Simple brain dump
  • Use only:
    • Today
    • All / Inbox
  • Every idea or task goes to Inbox
  • Each morning, move a few items to Today
  • Never touch routines, times, or calendar in this mode
Good if you feel overwhelmed. You basically treat Aavot like a digital sticky note wall.
Mode B: Time anchored day
This is where I slightly disagree with both @himmelsjager and @waldgeist:
jumping into lots of routines or keeping everything undated can make the app feel abstract.
Try:
  • Assign a date to almost everything
  • Assign a time only to 2 to 4 tasks a day
  • Keep the rest as “Today” with no times
  • Use the Calendar view only to see whether your day is overloaded
This balances structure with flexibility.
Mode C: Routine focused
Once you trust Aavot:
  • Move repeating chores out of your head:
    • Bills
    • Weekly review
    • Housework
    • Study blocks
  • Put those in Routines
  • In Today, focus on 3 to 5 one-off tasks, everything else is “autopilot” from routines
This works if your life has a lot of repeating patterns.
Pick one mode for a week. Do not mix all three at once.
2. Minimal configuration that actually matters
Everyone dives into notifications and themes. I’d prioritize:
  1. Default new task settings
    • Make default due date = “No date” or “Today” depending on your chosen mode
    • Turn off automatic priority for new tasks if that exists
  2. Completion behavior
    • If subtasks vanish in a confusing way, switch to “show completed” for subtasks only
    • Keep whole completed tasks hidden after a while so Today does not become a graveyard
  3. Carry over logic
    • Some versions of Aavot can auto move unfinished tasks to the next day
    • I strongly suggest you turn this off at first
    • Manually decide what moves so you do not end up with a growing blob you ignore
3. How to “read” the Today screen
Aavot often mixes overdue, today, tomorrow, timed, untimed. That visual mess is what trips most people.
Try reading Today in this order:
  1. Timed items first
    • These are your “appointments with yourself”
  2. Undated / date only items
    • Pick 3 that must happen
  3. Overdue items last
    • Either reschedule or delete, do not just scroll past them
So you are not asking “What did Aavot decide I should do” but “What has a clock, what are my 3 must-dos, what do I refuse to carry any longer.”
4. Pros and cons of using Aavot like this
Pros for Aavot App
  • Flexible enough to be:
    • Simple checklist
    • Daily planner
    • Routine tracker
  • Routines and recurring tasks reduce mental load once tuned
  • Calendar integration makes timeboxing possible without a separate app
  • Task views (Today vs All) let you separate “now” from “someday”
Cons for Aavot App
  • Interface feels busy until you aggressively hide what you do not use
  • Too many routine or recurring tasks can flood Today if you are not careful
  • Auto carry over / overdue handling can create clutter and guilt if misconfigured
  • Learning curve is steeper than most basic to do apps
5. Where @himmelsjager and @waldgeist fit in
  • @himmelsjager gave a very structured “set everything up properly” path
  • @waldgeist showed how to strip Aavot down so it behaves like a dumb checklist
Both are useful, but if they leave you still confused, try my “three modes” approach: choose one mode that matches your brain and ignore everything else.
If you describe which of these modes sounds closest to how you want to work (or drop a redacted screenshot of your Today screen), it is pretty easy to translate that into specific taps and settings for your version of the Aavot App.
