Need help switching Javascript logic without breaking my app
I’m trying to switch some existing Javascript logic to a new approach, but every time I change the code, parts of my app stop working or throw console errors. I’m not sure if I should refactor functions, change event handlers, or reorganize my files. Can someone explain the right way to switch Javascript implementations safely and what common pitfalls to avoid
First thing, stop changing everything at once. You want small, safe steps.
Here is a workflow that helps avoid breaking the app every time you switch logic.
  1. Add new logic next to the old one
    Do not rip out the old function.
    Example:
    Old: handleSubmit
    New: handleSubmitV2
    Keep both. Wire a small test path to V2 only, like a hidden button or a test route.
  2. Isolate side effects
    Look for code that:
    • touches DOM (document.querySelector, innerHTML, etc)
    • does network calls (fetch, axios)
    • writes to global state or window
    Keep those in small wrapper functions.
    Your “logic” functions should receive data and return data only.
    That makes refactors safer.
  3. Add basic tests, even tiny ones
    If you do not use a test framework, log and compare.
    Example pattern:
    const oldResult = oldLogic(input)
    const newResult = newLogic(input)
    console.log(‘compare’, { oldResult, newResult })
    Run that on real user flows.
    Fix any mismatch before switching.
  4. Freeze the public API of functions
    When you refactor, do not change:
    • number of arguments
    • argument types
    • return type
    If you must change them, add an adapter.
    Example adapter:
    function handleSubmitAdapter(event) {
    const formData = extractFormData(event.target)
    return handleSubmitV2(formData)
    Then replace event handler with handleSubmitAdapter instead of handleSubmitV2 directly.
  5. Deal with event handlers carefully
    Common problems:
    • losing “this” context
    • not calling preventDefault
    • binding multiple times and causing duplicate calls
    Prefer:
    element.addEventListener(‘click’, onClick)
    function onClick(event) {
    event.preventDefault()
    handleClickV2(event)
    Avoid inline handlers like onclick=‘someFunc()’ while refactoring.
  6. Watch for async changes
    If old code used callbacks and new uses async/await, check error paths.
    Old:
    doSomething(input, function(err, result) {
    if (err) showError(err)
    else showResult(result)
    New:
    async function doSomethingWrapper(input) {
    try {
    const result = await doSomethingV2(input)
    showResult(result)
    } catch (err) {
    showError(err)
    Keep the success and error behavior identical.
  7. Use feature flags
    Simple flag:
    const useNewLogic = false
    function handleThing(args) {
    if (useNewLogic) return handleThingV2(args)
    return handleThingOld(args)
    Flip it to true when you trust the new code.
    If things blow up, set it back to false fast.
  8. Read console errors closely
    Typical patterns:
    • “undefined is not a function” means the function you wired is missing or not bound
    • “Cannot read property X of undefined” means something in the new path changed shape
    Put console.log before the crash:
    console.log(‘debug’, { arg1, arg2 })
    Check types and value shapes.
  9. Refactor in this order
    • Pure logic functions first
    • Then data fetching or API calls
    • Then DOM and event hookup code
    The closer to the UI, the more things break, so treat that part last and in tiny steps.
  10. When stuck, do a minimal repro
    Copy the failing part into a small HTML + JS file.
    Remove extra code until you have a 20–30 line example that still fails.
    The bug usually shows up clearly there.
If you share a small snippet of the old function and your new version, plus the exact console error text, people can point to the exact line that is causing the issue.
A lot of what @vrijheidsvogel said is solid, but I’d actually flip the way you think about this a bit.
Right now you’re probably doing:
“Change code → reload app → random explosion in console → panic.”
Try to turn it into:
“Lock current behavior → describe it → then change implementation.”
Some concrete stuff that complements their points:
  1. Start by documenting what the old code actually does
    Not comments, not intent, reality.
    For a function you’re about to change, write down:
  • What are the inputs (real values you’ve seen, not just types)?
  • What are all the possible outputs?
  • What side effects does it trigger (DOM, network, globals)?
  • In what order do those side effects happen?
That last part is where people get burned. You “only” moved a line or changed from sync to async and suddenly events fire in a different order and the UI goes weird.
  1. Don’t be afraid to change the public API, just don’t do it everywhere at once
    I slightly disagree with the “freeze API” idea as a blanket rule. Sometimes your old API is actually the problem. But:
  • Change the API in one tiny place
  • Immediately fix only the direct callers
  • Run the app, no “while I’m here” edits
If you need a bigger API change, do it as a series of small, boring changes instead of a heroic “new architecture” commit.
  1. Make “switching logic” mostly a wiring problem
    Instead of jumping into your whole app, create a very small composition layer:
// central place
function handleSubmitFacade(event) {
  const data = extractFormData(event.target)
  if (window.__USE_NEW_LOGIC__) {
    return handleSubmitNew(data)
  } else {
    return handleSubmitOld(data)
Then everywhere in the UI you only ever refer to handleSubmitFacade.
All future experiments happen behind that facade. Most breakage comes from wiring the new function directly into the UI and accidentally skipping some old behavior.
  1. Compare behavior at the edges, not just in the middle
    @vrijheidsvogel showed comparing oldLogic vs newLogic. Good start, but you also want to compare the actual “visible” result:
  • For DOM: snapshot HTML before & after, or at least compare key bits:
    console.log('old text', oldElement.textContent)
    console.log('new text', newElement.textContent)
  • For API calls: log the previous payload and the new payload and diff them
  • For state objects: console.log(JSON.stringify(oldState), JSON.stringify(newState))
Sometimes the pure function outputs match, but some tiny formatting or timing difference at the edge breaks things.
  1. Be extremely suspicious of “just” changing event handlers
    If things blow up after you “just” swapped a handler, check:
  • Did the old handler rely on this inside? New one might not.
  • Did the old handler run synchronously and your new one is async and returns later, messing up race conditions?
  • Did you move preventDefault to after some async call? That can change behavior too.
When you migrate an event:
button.removeEventListener('click', oldHandler)
button.addEventListener('click', newHandler)
Make sure the old one is actually removed, or both will run and you get weird doubled side effects.
  1. Log intent, not just data
    Instead of spamming console.log(value), log “stories”:
console.log('[submit] using OLD logic', { data })
console.log('[submit] using NEW logic', { data })
That lets you read the console like a timeline:
  • “Clicked button”
  • “Using NEW logic”
  • “Fetch started”
  • “Error thrown: Cannot read property X of undefined”
You’ll see where the new path diverges from the old one.
  1. Ruthlessly avoid mixed old/new inside the same function
    If you have something like:
function handleSubmit() {
  oldStep()
  newStep()
  oldStep2()
You’re asking for pain. That’s the “half migrated” state that breaks everything. Either:
  • Keep old version intact and call it entirely, or
  • Create a clean new version and route to that
Any Frankenstein mix should be very temporary and isolated, and you should delete it as soon as you verify the new flow.
  1. When a change breaks stuff, don’t immediately revert the code
    Hot take: quick reverts can hide what actually went wrong. Better:
  • Leave the broken version in a branch
  • Add a couple of console.logs or even debugger statements
  • Step through and see the bad state
Then fix with understanding instead of panic. Panic refactors are how you end up with three half-broken versions of the same logic.
If you can paste one of the old functions, your new attempt, and the exact console error, you’ll probably get a very precise “this line, this assumption, this shape changed” answer. The bug is usually not in the big new logic, it’s in one tiny assumption that used to be true and isn’t anymore.
You already got strong process advice from @nachtschatten and @vrijheidsvogel, so I’ll focus on how to think about the code itself rather than more knobs and flags.
1. Stop thinking in “old vs new logic”, think in contracts
Most breakage happens because a function silently changes its contract:
  • Input shape
  • Output shape
  • When it runs (timing)
  • How many times it runs
Before you touch anything, write a tiny “contract” next to the function:
// handleSubmit contract:
// input: DOM event from form submit
// reads: form fields: email, password
// calls: api.login({ email, password })
// side effects: disables button, shows error on failure, redirects on success
When you rewrite, force yourself to keep that contract identical unless you consciously decide to change it and then deliberately fix each caller. That mindset alone cuts your “random explosions” by a lot.
Here I mildly disagree with the idea that API changes are fine in small bits. In most UI-heavy apps, changing contracts even for a “small” area tends to leak out. I’d rather keep the outer contract frozen and only swap internals until you are very sure.
2. Use “probe” wrappers instead of feature flags everywhere
Feature flags are fine, but if you sprinkle if (useNewLogic) all over, the codebase gets noisy and confusing.
A cleaner pattern is a single “probe” wrapper that temporarily shadows the original function:
// original
function calculatePrice(cart) {
  // old logic
// probe wrapper during migration
function calculatePriceProbe(cart) {
  const oldVal = calculatePrice(cart)
  const newVal = calculatePriceV2(cart)
  if (JSON.stringify(oldVal) !== JSON.stringify(newVal)) {
    console.warn('[price mismatch]', { oldVal, newVal, cart })
  return oldVal  // app still uses safe behavior
Then, temporarily wire the app to calculatePriceProbe. You get live comparisons in real flows without changing visible behavior. Once the console is quiet, flip the return to newVal, then later delete the probe.
This pattern keeps the app stable while you freely trash and improve calculatePriceV2.
3. Treat timing as a first-class concern
A lot of “it broke when I refactored” is actually “it now happens earlier/later”.
Checklist when converting or moving logic:
  • Did a sync function become async?
  • Did something that used to run on event now run on render?
  • Did you move actions from “after DOM updated” to “before DOM updated”?
For example, if your old code was:
form.onsubmit = function (e) {
  e.preventDefault()
  validate()
  submit()
  showSuccess()
and you refactor to:
form.addEventListener('submit', onSubmit)
async function onSubmit(e) {
  e.preventDefault()
  await submitV2()  // validate is inside here now
  showSuccess()
Even if the logic is “the same”, you may:
  • Show success a bit later
  • Trigger different error paths
  • Hit race conditions with other listeners
When you see new console errors, always ask: “did I accidentally change when this runs?”
4. Use “thin” UI handlers, “fat” logic functions
You mentioned not knowing whether to refactor functions or event handlers. The safe pattern:
  • Event handlers = very thin: extract data, call logic, apply minimal UI changes
  • Logic functions = fat: all the decisions, branching, data transformation
Example:
// thin
  e.preventDefault()
  const data = getFormData(e.target)
  const result = await handleLoginFlow(data)  // fat function
  applyLoginResultToUI(result)
Now you can swap handleLoginFlow repeatedly with almost zero risk of breaking DOM interactions, because the handler and UI application stay stable.
@nachtschatten talked about facades; this is similar but with a stricter separation between “wiring” and “thinking”.
5. Prefer visible “health checks” over raw console reading
Instead of relying only on console errors, add tiny “health indicators” in your UI for the parts you are touching:
  • A hidden debug panel that shows current state shape
  • A small text block that says “submit v2” vs “submit v1” so you know which path you hit
  • A quick visual difference checker for DOM sections (e.g. show JSON of key state under a details tag)
This gives you a fast feedback loop that is more concrete than scanning console spam.
6. Do not refactor across multiple axes at once
This is different from “small steps.” You can take a small step that changes three things at the same time:
  • Move logic to a new file
  • Rename functions
  • Change data structures
Then debugging becomes painful because you cannot tell what caused what.
Pick only one axis per refactor:
  • Step 1: move file, keep implementation intact
  • Step 2: rename function, keep arguments and body intact
  • Step 3: change data shape, keep name and file stable
Breaking the work this way feels slower but in practice you track down issues much faster.
7. Pros & cons of this “contract + probe” style
  • Very low risk: old behavior is preserved until you explicitly flip
  • Bugs surface via deliberate comparisons instead of user reports
  • Refactor sessions are less stressful because the app is rarely in a broken state
  • Encourages clearer boundaries between UI, wiring, and logic
  • Temporarily more code: you are keeping old, new, and probe wrappers
  • Requires discipline to delete probes and old logic once stable
  • If you overuse it, the project can feel littered with “v2” and “probe” names
Compared to the workflows from @nachtschatten and @vrijheidsvogel, this approach leans harder on explicit contracts and probes instead of flags/routes. Their advice is great for process and tooling; this is more about how you shape the actual functions so switching logic does not feel like defusing a bomb.
If you post one concrete “old vs new” pair and the exact console error, it is usually just one broken contract: some argument you thought would always be there, or one side effect that moved in time.
