Need help removing cookies from my iPhone
I’m trying to clear cookies on my iPhone because some websites keep logging me in automatically and showing old data. I’ve checked Safari settings but I’m not sure which options to use without messing up important saved info. Can someone walk me through the right steps to remove cookies safely and explain what I might lose when I do this?
Short version, if you want to clear cookies on iPhone without nuking everythng:
  1. Clear Safari cookies but keep passwords
  2. Remove cookies for specific sites
  3. Adjust future cookie behavior
  4. Optional helper app
Here is how.
  1. Clear all Safari cookies, keep logins in iCloud Keychain
This wipes site data, but saved passwords in iCloud Keychain stay.
On iOS 17 or 16:
  1. Open Settings
  2. Scroll to Safari
  3. Tap Clear History and Website Data
  4. Confirm
What this does:
• Deletes cookies, cache, and browsing history
• Keeps passwords and autofill info stored in iCloud Keychain
• Logs you out of most sites so they stop auto logging in and serving old data
You might lose custom settings on some sites, like themes or language.
  1. Clear cookies for specific websites only
If you only want to fix a few annoying sites:
  1. Settings
  2. Safari
  3. Tap Advanced at the bottom
  4. Tap Website Data
  5. Let it load, takes a bit
  6. Use the search box at the top to find the problem site
  7. Swipe left on the site entry
  8. Tap Delete
Or tap Edit, then select multiple sites and remove them.
This keeps other sites untouched and still logged in.
  1. Turn off automatic login behavior from cookies
If you want sites to stop keeping long sessions:
  1. Settings
  2. Safari
  3. Under Privacy and Security, check:
    • Prevent Cross-Site Tracking: turn this on
    • Block All Cookies: do not turn this on if you want to stay logged in anywhere. It breaks logins for many sites.
  4. Scroll to Clear History and Website Data and use it when things start acting weird again
  5. If you use Chrome or another browser on iPhone
Those have their own cookies.
Chrome:
  1. Open Chrome
  2. Tap the three dots, bottom right
  3. Tap History
  4. Tap Clear Browsing Data
  5. Select Cookies, Site Data and Cached Images and Files
  6. Leave Passwords unchecked if you want to keep them
  7. Tap Clear Browsing Data
Do this for each third party browser you use.
  1. Extra tip if websites keep showing old data
Sometimes it is cache, not only cookies.
In Safari:
  1. Settings
  2. Safari
  3. Clear History and Website Data, as above
Or for 1 site, clear its Website Data entry as in step 2, then force close Safari:
• Swipe up from bottom, hold
• Swipe Safari away
• Reopen Safari and reload the page
  1. Optional helper: clean up junk and speed things up
If your iPhone browser and storage feel messy, a cleanup app helps.
One option is Clever Cleaner App for iPhone. It helps remove junk files, duplicates, and other leftover data so Safari and other apps run smoother.
You can check it here:
Clever Cleaner App for faster and cleaner iPhone storage
That will not manage browser cookies per site, but it helps with:
• Clearing out large temporary files
• Removing duplicate photos and videos
• Freeing storage so Safari and other apps load faster
If you want the safest route for your cookies:
• Start with site specific removal under Safari → Advanced → Website Data
• If issues stay, use Clear History and Website Data
• Leave iCloud Keychain on so you keep your logins and autofill info
If sites keep logging you in and showing stale junk, you’re right to look at cookies, but you don’t have to carpet-bomb everything like @cazadordeestrellas suggested in parts of their post.
They already nailed the “how to clear” steps, so I’ll skip that repetition and focus on how not to mess up the stuff you care about and a few extra tricks.
1. Decide which problem you’re really fixing
Different behavior = different fix:
  1. Site keeps logging you in when you don’t want it to
    That’s a login/session cookie problem.
    → Fix by deleting cookies for that site only.
  2. Site shows old data (old cart, old feed, outdated page)
    That’s usually cache + cookies mixed.
    → Fix by clearing that site’s data, then fully reloading the page.
  3. You want a “fresh start” but keep passwords
    That’s a full Safari reset, but not touching iCloud Keychain.
Try to pick which of the three you actually want before tapping anything.
2. When not to hit “Clear History and Website Data”
I know @cazadordeestrellas said to use it, and it’s often fine, but I’d actually avoid it at first if:
  • You rely on being logged into banking, work, or 2FA-heavy sites
  • You have a ton of tabs open and like your history for backtracking
That button is basically:
“Safari amnesia: forget sites, cookies, cache, and history in one shot.”
Instead, start surgically:
  • Go to Settings → Safari → Advanced → Website Data
  • Only nuke the specific annoying sites that keep auto logging you in
If that fixes it, you never needed the global nuke.
3. Extra trick: hard refresh for a single site
Even after deleting its data, Safari sometimes clings to old stuff.
On the problem site:
  1. Open the page in Safari
  2. Tap in the address bar and pull down to refresh
  3. If it still acts old, close the tab, open a brand new tab, type URL again
Not magic, but it often forces a proper reload of fresh content.
4. Prevent sites from being too “sticky” in the future
Without going as far as “Block All Cookies” (which is a pain):
  • In Settings → Safari → Privacy & Security:
    • Prevent Cross-Site Tracking: ON (agree with @cazadordeestrellas here)
    • Block All Cookies: OFF unless you enjoy breaking logins everywhere
What that does in practice:
  • Sites can still log you in, but they can’t track you all across the web as easily
  • You keep normal logins working
If you really hate long auto-logins, just plan to clear that site’s data every once in a while instead of trying to globally block cookies.
5. Don’t forget other browsers
One thing people overlook: if you sometimes open links in Chrome, Edge, Firefox, etc., they all have their own cookies. Clearing Safari won’t touch those at all.
Quick sanity check:
  • If the “old data” or auto-login only happens in one browser, fix cookies there, not everywhere.
6. Storage clutter vs cookies (different thing, but related)
Cookies are tiny. If your phone also feels laggy or “full,” that’s usually:
  • Cached files from apps
  • Duplicate photos & videos
  • Old app leftovers
That’s where something like the Clever Cleaner App actually makes sense. It will not be your fine-grained cookie manager, but it will help free up storage and get rid of junk so Safari and other apps behave better overall.
If you want an easy way to clean out junk files, large temp data, and duplicates, check out
this iPhone cleanup tool that helps reclaim storage and speed.
Use it for storage and clutter issues, then use Safari’s own settings for cookie and site-specific stuff.
7. Safe “recipe” so you don’t break important logins
If I were in your spot and worried about losing important saved stuff, I’d do this order:
  1. Fix specific “problem” sites first
    • Settings → Safari → Advanced → Website Data
    • Search the site, delete only that
    • Reopen Safari, try again
  2. If that still fails
    • Then consider Clear History and Website Data
    • Make sure iCloud Keychain is on so passwords autofill again
  3. If you keep hitting this issue regularly
    • Maybe review how often you stay logged in on certain sites
    • Periodically clear only those sites’ data every few weeks
You won’t “mess up” your important stuff if you start with targeted cleanups and only escalate to the full clear when things are really stuck.
