My Zoom app keeps freezing and crashing during important meetings, even after reinstalling and updating my OS. I’ve tried checking my internet connection and closing background apps, but nothing helps. I need advice on what settings to check or logs to look at so I can figure out whether this is a device issue, a network problem, or something with my Zoom configuration.
Zoom freezing like that usually points to either hardware load or a conflict, not only the network. Since you already reinstalled and updated OS, try going a bit more surgical.
Check CPU, RAM, GPU during a call
Open Task Manager / Activity Monitor.
If CPU hits 90–100% when Zoom is on, lower load.
• Turn off HD video in Zoom: Settings > Video > uncheck HD.
• Turn off “Touch up my appearance” and “Adjust for low light”.
• Disable virtual background or blur. Those hit the GPU hard. -
Disable hardware acceleration
In Zoom desktop: Settings > Video > Advanced.
Turn off hardware acceleration for sending, receiving, and processing video.
Restart Zoom after that. This fixes a lot of random freezing on certain GPUs. -
Try the web client
Log in via browser: https://zoom.us/join and pick “Join from your browser”.
If browser meetings run fine while the app crashes, the issue is the native client or its interaction with drivers. -
Update or roll back graphics driver
On Windows
• Update GPU driver from Nvidia / AMD / Intel site.
If the issue started after a driver update, roll back to the previous version via Device Manager.
On macOS
• Make sure you are on the latest minor update for your macOS version. -
Check conflict apps
These often mess with Zoom:
• Screen recorders, overlays, game capture tools.
• VPN clients, “secure web” filters from antivirus.
• Third party audio tools like virtual audio cables, some EQ apps.
Temporarily exit them fully, not only close the window. Test a call after that. -
Create a fresh Zoom profile on your machine
Sometimes corrupted local data survives a reinstall.
• Log out of Zoom.
• Exit Zoom completely.
• Delete or rename the Zoom settings folder:
- Windows: C:\Users[you]\AppData\Roaming\Zoom
- macOS: ~/Library/Application Support/zoom.us
• Log in again.
You lose local preferences, which is fine for testing.
Check security / antivirus
Over-aggressive antivirus or firewall can stall Zoom.
• Temporarily disable “web shield” or “network inspection” modules.
• Add Zoom to allowlist. On Windows the main executables sit in C:\Users[you]\AppData\Roaming\Zoom\bin.
Re-enable protection after the test. -
Try different audio and video devices
Bad drivers on headsets or webcams cause crashes.
• In Zoom, switch mic and speaker to “Same as system” or to a different device.
• If you have a USB headset or external webcam, unplug and test with built-in ones. -
Check logs and send to Zoom
Zoom keeps logs here:
• Windows: C:\Users[you]\AppData\Roaming\Zoom\logs
• macOS: ~/Library/Logs/zoom.us
If you see repeated entries at crash time that mention video or network, that helps narrow it down. You can zip that folder and send to Zoom support. They respond faster when you give logs, not only a description. -
As a workaround for important meetings
Until this is fixed, reduce risk:
• Use wired ethernet if possible.
• Turn off your own video and keep only audio.
• Join from phone app as a backup and keep it connected on mute, so if the desktop app freezes you unmute phone and continue.
If you post your OS version, CPU, GPU and whether you use any VPN or special security tools, people can guess the likeliest conflict instead of you trying random things.
Zoom crashing like that after OS updates + reinstall usually screams “driver / environment weirdness” more than plain resource load, so I’m gonna poke at slightly different angles than what @techchizkid already covered.
Try these in this order:
Create a fresh OS user account
Not just a Zoom profile. New local user on Windows/macOS, install Zoom there, join a test meeting.
If it works fine, something in your main profile’s config (policies, startup tools, registry junk, corrupted profile) is poisoning Zoom. -
Test on a totally different network
You said you checked the internet, but try:
- Phone hotspot
- Another Wi‑Fi (friend / office / cafe)
If Zoom only dies on your usual network, look at: - Router QoS rules
- “Smart” security features on the router
- ISP‑issued security apps that run on your PC
- Kill all overlay / hook software at startup
Not just screen recorders. Things that hook into video/audio or windows:
- Razer / Logitech / Corsair RGB suites
- FPS counters, Discord overlay, GeForce Experience in‑game overlay
- Nahimic / Sonic Studio / Realtek “enhancement” tools
Disable them from starting with the OS, reboot, then test Zoom.
- Check Windows Event Viewer / macOS Console at the exact crash time
Look for:
- Application Error with zoom.exe and a faulting module like ntdll.dll, ucrtbase.dll, some audio DLL, or GPU DLL
- Kernel / driver errors right before the crash
If it always points to the same DLL (for example, an audio driver), that’s your suspect and you can reinstall or replace that driver specifically.
- Turn off all “enhanced” audio stuff
Zoom audio conflicts are underrated. Try:
- In Windows Sound settings, disable “Enable audio enhancements” on your mic & speakers
- Uninstall virtual audio devices (VB‑Cable, VoiceMeeter, some conference bridge tools)
- Temporarily unplug USB audio interfaces and use only built‑in mic/speakers
Try the Windows Store / macOS App Store version of Zoom
If you currently use the direct download, install the Store build instead, or vice versa. They’re packaged slightly differently and sometimes one works fine while the other crashes like crazy. -
Clean boot the OS
On Windows:
- msconfig → Selective startup → Disable all non‑Microsoft services
- Disable all Startup items in Task Manager
Reboot, run only Zoom, test a meeting.
If it’s stable like this, re‑enable stuff in chunks until the crashes come back so you can catch the culprit.
- Turn off fancy power saving & CPU throttling
Zoom gets grumpy on certain laptops when power management is aggressive.
- Set Windows Power Plan to “High performance” or “Best performance”
- In laptop vendor tools (Lenovo Vantage, Dell Power Manager, etc.), set performance to max or disable “silent” modes while testing
Sometimes those modes mess with GPU/CPU state changes and Zoom falls over.
- Check for enterprise / security policies
If this is a work machine, IT tools can silently interfere:
- Endpoint inspection, DLP, SSL inspection, or “zero trust” clients that hook into network traffic
- Browser isolation agents
Ask if they can temporarily disable or exclude Zoom to test.
Network SSL inspection can cause weird half‑crashes where the app UI locks even though CPU is fine.
- Nuclear Zoom wipe
If nothing else helps:
- Uninstall Zoom
- Remove any Zoom virtual audio devices from Device Manager / Audio MIDI Setup
- Delete the folders @techchizkid mentioned plus
- On Windows: C:\Users\you\AppData\Local\Zoom
- Reboot
- Install a different Zoom build: either one version older or newer than what you had.
For critical meetings, I’d honestly:
- Join from phone app as primary
- Join from desktop as secondary “screen share” device with video off
That way if the desktop app faceplants, you’re still talking on mobile and nobody knows your PC is having a meltdown.
If you can post exact OS version, laptop/desktop model, and whether it’s a company‑managed device, it’d be way easier to narrow which of these is most likely instead of just randomly flipping switches.
Skip the usual suspects already covered by @reveurdenuit and @techchizkid; I’ll zoom in (no pun intended) on a few angles they didn’t lean on much and occasionally disagree.
1. Don’t rely on “reinstall & update OS” as proof the system is clean
Reinstalling the Zoom app and updating the OS often does not touch:
- Old system codecs
- Legacy conferencing tools
- Vendor bloatware audio/video add‑ons
Those can still break Zoom even after reinstalls. Instead of another reinstall, look for:
- Old conferencing clients: Cisco Webex, BlueJeans, GoTo, old Teams add‑ins
- Old codec packs: K‑Lite, CCCP, “video enhancer” packs
Uninstall them, then reboot and test Zoom again. I’ve seen Zoom stop freezing immediately after ripping out an ancient Webex plugin.
2. Turn off “silent” network shapers that look fine in speed tests
You said you checked your internet. I’d still question that, but not in the usual “run a speed test” way.
Look for:
- “Gaming” or “Smart QoS” modes in your router
- ISP‑branded accelerator / booster software on your machine
- Cloud backup tools (OneDrive, Google Drive, Dropbox, iCloud) heavily syncing while you’re in a meeting
Speed tests can still look normal while these spike latency or stall packets just enough to freeze Zoom’s UI.
Try:
- Pausing all cloud backup / sync tools during calls
- Disabling router QoS / “Smart Queue” features for one test meeting
- If you use any ISP helper client, exit it fully before a call
If the app stops freezing, you found a hidden network culprit even though bandwith “looked” fine.
3. Validate your camera pipeline instead of just swapping devices
Others suggested changing camera devices; I’d go one step more methodical:
- Install a lightweight camera test tool (or use the OS built‑in camera app).
- Start your webcam there and leave it running for 10–15 minutes.
- If that freezes, you have a camera / USB / driver issue, not a Zoom issue.
Things that often break only during Zoom:
- USB‑C hubs with several devices hanging off a single port
- Long USB extension cables
- Cheap capture cards pretending to be webcams
As a test, plug the webcam directly into the laptop, no hub, and try Zoom. If you are on a laptop, also try:
- Disabling any vendor webcam enhancements in their utility (HP Camera, Lenovo Vantage camera tweaks, etc.)
4. Scrap aggressive “auto” settings in Zoom instead of only killing features
I slightly disagree with the idea of just turning features off and calling it a day. Zoom has some auto behaviors that misfire on marginal systems.
Try:
- In Zoom Audio: turn off “Automatically adjust microphone volume” and set a fixed level
- In Zoom Video: disable “Mirror my video,” and lock your camera to 16:9, avoid “Original ratio” if it keeps renegotiating
- In “Share Screen” options: disable “Use hardware acceleration for screen sharing” separately from video accel settings
These reduce Zoom’s constant renegotiation of stream formats and levels, which can reduce those short UI freezes.
5. Look at system‑wide timeout & sleep behavior
Zoom can hang on systems that are over‑aggressive with power saving during meetings:
- USB selective suspend cutting power to webcam
- PCI Express power management slamming the GPU down mid‑call
- Screen timer trying to trigger while video is active
Try for one meeting:
- Set display sleep to “Never”
- Disable USB selective suspend in power options (Windows)
- Set laptop lid close action to “Do nothing” and test with lid open
- On vendor tools, disable “eco” or battery saver profiles specifically during meetings
If that stops the pattern of mid‑meeting freezes, tune from there instead of living in high‑performance 24/7.
6. Profile time to freeze and pattern of crashes
Before trying more random toggles, watch for patterns:
- Does it always freeze when you start sharing screen, or when someone else does?
- Only in meetings over N minutes?
- Only with a specific account (work vs personal)?
If you spot “only when I share screen,” then focus on:
- Lowering screen share resolution (Advanced share options)
- Sharing a single app window instead of full desktop
- Disabling any multi‑monitor management tools while sharing
If it is “after 20–30 minutes every time,” that can hint at a slow memory leak from another tool hooking Zoom.
7. Test account‑specific problems
Everyone focuses on OS users and configs, but Zoom account settings synced from the cloud can also be weird.
Try:
- Sign out of your main Zoom account in the app.
- Join a meeting as a guest or using a different account (personal or free account).
If guest/different account works fine, then:
- Some advanced setting on your main account (set by your org) may be clashing
- Things like forced virtual background, forced encryption modes, or locked recording policies can stress borderline machines
You’d then need to have whoever manages your account review policy‑level settings.
8. Have a deliberate “redundant workflow” for important calls
Until this is nailed down, run your setup like a small failover system, not a single point of failure:
- Primary: Desktop Zoom with video off unless needed, minimal effects
- Secondary: Phone Zoom app connected and muted, ready to take over audio
- Optional: A browser-based join on a second profile or different browser as a backup viewer only
If desktop freezes, audio on phone takes over instantly and you just rejoin on desktop when you can. There is no perfect “product title” that magically fixes random Zoom freezes, so operational redundancy is your best bet in the short term.
9. Pros & cons of sticking with the Zoom desktop app
Since you mentioned you already reinstalled, it is worth clarifying why you might still persist with it or move away from it for a while.
Pros of the Zoom desktop app
- Full feature set: breakout rooms, advanced screen share, virtual backgrounds
- Better keyboard shortcuts and window management than the browser in long meetings
- Generally lower CPU vs some browser combinations once it behaves properly
Cons of the Zoom desktop app
- More sensitive to driver conflicts, hooks, and audio / video quirks
- Updates can occasionally introduce new bugs before they are stable
- Heavier local footprint and more moving parts than web client
Competitors like the approaches suggested by @reveurdenuit and @techchizkid focus heavily on driver / overlay / clean‑boot diagnostics, which is solid. I’d just combine their hardware‑and‑driver focus with the additional system behavior and account pattern checks above so you are not endlessly toggling the same three settings.
If you post your exact OS version, machine model, and whether this is a managed work device, we can probably narrow the suspect list a lot instead of you continuing to try broad guesses.
