I just started trying to use Sora AI, but I’m confused about how it works and what steps I need to follow to create videos properly. I’ve looked for beginner tips, setup help, and clear instructions, but I’m still stuck and need simple guidance to get started.
Start simple. Sora works from a text prompt. You type what you want, pick settings, generate, then refine.
Basic flow:
- Open Sora in your OpenAI account.
- Choose video generation.
- Write a prompt with 4 parts:
subject, action, setting, camera style.
Example:
“A red bicycle moves through a rainy city street at night, neon reflections on wet pavement, slow tracking shot, cinematic lighting.”
Then set:
- Length. Start with short clips.
- Aspect ratio. 16:9 for YouTube, 9:16 for Shorts.
- Quality or speed mode, if shown.
- Variations, if available.
Best beginner tip. Keep prompts clear. One scene. One action. One mood. If you ask for 10 things, results get messy fast.
Prompt formula:
[subject] + [action] + [location] + [lighting] + [camera move] + [style]
Example:
“A corgi running across a beach at sunrise, soft golden light, low angle, handheld camera, realistic film style.”
If the result looks off, change one thing at a time. Do not rewrite the whole promt every try. Fix:
- Motion too weird, ask for slower movement.
- Scene too busy, remove extra objects.
- Wrong style, say realistic, animated, film, claymation, etc.
- Bad framing, ask for close-up, wide shot, overhead shot.
A lot of new users miss this part. Sora is better at specific instructions than vague ones. “Make it cool” is weak. “Close-up of a chess board, dramatic side lighting, slow push-in camera” works better.
If image upload is enabled on your account, use it as a reference. That helps with character look and scene consistency.
For multi-shot videos, generate clips separately first. Then edit them together. Trying to force a whole short film in one prompt usally turns into chaos.
If you want, post one prompt you tried and I’ll clean it up into a better version.
What tripped me up at first was thinking Sora is an editor. It really isn’t. It’s more like a scene generator. So the easiest way to use it is to decide your goal before you touch the prompt box.
If you want a single good clip:
- Decide the outcome first, not the wording first.
- Pick one subject and one moment.
- Generate 2 to 4 versions.
- Keep the best one and refine from there.
I slightly disagree with @himmelsjager on one thing: sometimes “start super simple” helps, but if you go too barebones, Sora fills in gaps in weird ways. I’ve had better results giving it a clear visual intention, like mood, era, and texture, not just object + action.
Example:
“1970s-style documentary footage of a fisherman on a foggy lake at dawn, muted colors, light camera shake, natural motion.”
That tends to work better than just “a fisherman on a lake.”
Also, don’t chase perfection in one generation. That’s where beginners burn time fast. Treat it like this:
- pass 1: get the composition
- pass 2: fix motion
- pass 3: fix style
- pass 4: export and edit elsewhere
Another thing nobody explains well: negative steering matters if the tool allows it. If your clips keep getting extra people, weird hands, distracting movement, etc, tell it what to avoid. Not every version of the interface exposes that, but if it does, use it.
Practical setup stuff:
- short duration is easier
- vertical for TikTok/Reels, horizontal for YouTube
- save your prompts in a doc because you will forget what worked
- name each test clip, otherwise it becomes a mess real quick
And honestly, if you want a full video, do not expect Sora to handle script, pacing, scene continuity, voiceover, and final edit all in one go. That’s the part that confused me too. Generate assets in Sora, then assemble them in CapCut, Premiere, etc. Way less annyoing.
Biggest beginner mistake is treating How To Use Sora Ai like a “type prompt, get finished video” tool. I’d frame it more like previsualization plus clip generation.
A workflow that helped me:
- Write a 3-shot plan before opening Sora
- For each shot, define:
- subject
- environment
- camera behavior
- lighting
- duration
- Generate each shot separately
- Only then worry about transitions and music in another app
I slightly disagree with @himmelsjager on one point: making lots of variants early can waste credits if your shot idea is still vague. I’d lock the shot design first, then branch.
Good prompt structure:
“Close-up of wet neon street at night, reflections on pavement, slow dolly forward, cinematic lighting, realistic motion, 5 seconds, 16:9”
If results look off, change one variable only. Not five.
Pros for ‘’
- Fast concepting
- Great for visual mood tests
- Useful for short social clips
Cons for ‘’
- Continuity between shots can be inconsistent
- Prompt wording can be touchy
- Still needs external editing for polished final videos
Also check output settings before generating. Aspect ratio, length, and realism/style matter more than beginners think. If you keep changing all three at once, you won’t know what fixed the result.
