How To Split Screen On Android
I just switched to an Android phone and I keep hearing about the split screen feature, but I can’t figure out how to turn it on or use it properly. I’ve tried long-pressing app icons and swiping from the bottom, but nothing seems consistent. Could someone walk me through the steps to enable and use split screen on Android, and mention if it works differently on various versions or brands?
Split screen on Android is a bit different depending on the phone and version. I’ll break it down by the most common setups so you can test what matches yours.
First thing, check your Android version:
Settings → About phone → Android version
Then try these.
  1. Gesture navigation phones (no 3-button bar)
Most newer Samsung, Pixel, OnePlus, etc.
Method A:
  1. Open the first app you want.
  2. Swipe up from the bottom and hold to open Recent apps.
  3. Find that app card.
  4. Tap the app icon at the top of the card.
  5. Tap “Split screen” or “Open in split screen view”.
  6. Now pick the second app from the list below or from the app drawer.
Method B (some Samsung and Xiaomi):
  1. Open Recent apps.
  2. On some models you see “Split screen” under the app card or a two-rectangle icon.
  3. Tap that.
  4. Then pick the second app.
To exit split screen:
  1. Drag the divider bar all the way up or down.
  2. Or press Home then close from Recents.
  1. 3-button nav bar phones
If you have Back, Home, Recent keys:
  1. Tap the square/Recent button.
  2. On each app card, tap the icon at the top.
  3. Tap “Split screen”.
  4. Then choose the second app from the list.
If you long press the Recent button and nothing happens, the OEM disabled the shortcut. Use the app icon in Recents instead.
  1. Samsung One UI tricks
On Samsung, it hides in a few places.
A) Standard split:
  1. Open Recents.
  2. Tap the app icon.
  3. Tap “Open in split screen view”.
  4. Pick second app.
B) Pop-up view (floating window):
  1. Same, but tap “Open in pop-up view”.
  2. You can move and resize that window.
Settings worth checking:
Settings → Advanced features → Labs or Multi window
Enable things like:
• Swipe for split screen
• Swipe for pop-up view
Then you can:
  1. Swipe with two fingers from bottom to top on the screen to enter split screen on some Samsung versions.
  1. Some apps do not support split screen
If “Split screen” option is missing for a specific app:
• The app blocks multi window, common with some video players, banking apps, some games.
• Try with Chrome plus Messages as a test pair. Those usually work.
  1. If nothing at all works
Check this:
  1. Settings → System → Developer options.
  2. Look for “Force activities to be resizable”.
  3. Turn it on, then reboot.
    This helps with stubborn apps, but it is a bit hacky and might cause odd UI issues in some cases.
Also check if your phone is some “Lite” or older model from a brand like Nokia, Motorola, or budget devices. Some of them strip out or limit split screen in certain builds.
  1. Quick test flow
Try this step by step:
  1. Open Chrome.
  2. Go to a random webpage.
  3. Swipe up and hold to open Recents.
  4. Tap Chrome icon at top of its card.
  5. Look for “Split screen”.
  6. If present, tap it.
  7. Then choose YouTube or Messages as the second app.
If step 5 shows no split screen for any app, your ROM or skin might have it removed or it sits in a different UI spot. In that case, share your phone model and Android version in the thread. People with the same phone usually know the exact path.
Couple things to add on top of what @viajeroceleste already laid out, since Android’s split screen is annoyingly inconsistent.
First, don’t stress too much about long-pressing app icons on the home screen. On most phones that doesn’t trigger split screen at all, so that part of what you tried was never going to work. The useful spot is almost always the Recent apps view, not the launcher.
Where I slightly disagree with them: I wouldn’t jump into Developer options to “force activities to be resizable” unless you already know your way around weird app behavior. That toggle can break layout in some stubborn apps and make things uglier than it’s worth. Treat that as a last resort, not a normal step.
A few practical usage tips that help once you do get it working:
  • Think of split screen as “primary app on top / secondary on bottom.” Most launchers treat the first app you pick as the固定 one. If you keep losing the app you actually care about when you exit split screen, open that one first every time.
  • You can usually swap the two apps by tapping the divider line between them and looking for a little “swap” icon. Super handy when you realize the bottom app should have been on top.
  • Some video apps behave weirdly: picture-in-picture often works better than split screen for YouTube, Maps, etc. If you mainly want “watch + chat,” try enabling Picture-in-picture in Settings > Apps > Special app access, instead of fighting split screen.
  • Banking apps, DRM-heavy video apps, and some games are stubborn. If one specific app refuses to show the split option, don’t waste too much time; that’s intentional.
Since you said “swiping from the bottom does nothing,” double-check:
  • Settings > System > Gestures > System navigation
    Try switching between gesture navigation and 3‑button navigation and test split screen in both modes. Some skins behave way more sanely with the 3‑button setup.
If you post the exact phone model + Android version in the thread, people with that same device can usually say, “Tap this icon in Recents, ignore that one,” because each brand loves to hide it in slightly different spots.
Couple of angles that might help, building on what @viajeroceleste already covered but without rehashing the same “how to” steps.
First, I’d actually say: don’t give up on gesture navigation so quickly. They suggested trying 3‑button nav for sanity, which is fair, but on a lot of newer phones split screen is actually more reliable with gestures once you learn the exact swipe rhythm into Recents. The catch is timing: swipe up and hold a fraction of a second longer than you think, then look for the split icon on the app card. If you’re flicking too fast, you just go home instead.
Second, if split screen keeps feeling janky, think about workflow instead of the feature itself:
  • Use split screen mainly for “reference + action” combos, like browser on top, notes on bottom.
  • For “chat while watching,” I actually disagree slightly with treating split screen and picture-in-picture as either/or. Use PiP for something you barely need to interact with (Maps navigation, a video you’re mostly listening to), and stick to split screen when you need to actively tap in both apps a lot.
About stubborn apps: instead of forcing them to resize in Developer options (like was warned against), a safer trick is to use alternative apps that play nicer with multitasking. For example, some banking apps refuse split screen, but a companion budgeting app often works fine in split, so you can at least cross-check numbers.
You also mentioned long‑pressing icons on the home screen. That’s not “wrong,” it is just very manufacturer‑specific. Some skins actually do add a “Split screen” shortcut there, so once you know split screen works via Recents, it is worth checking the app icon menu again for your most used apps. If it is absent, that is just how your skin is set up, not something you are missing.
Since you were looking up “How To Split Screen On Android” in general, the big mindset shift is: treat split screen as a power feature with quirks, not a universal expectation. Pros: true side‑by‑side work, great for notes, messaging, docs. Cons: weird app exceptions, occasional lag, tiny touch targets on small screens.
Compared with what @viajeroceleste explained, I would experiment more with gestures and alternative apps before diving into Developer settings. If you share your exact model and Android version in the thread, people with the same device can usually point to the exact icon or gesture spot your manufacturer decided to hide split screen behind.
