How To Share Location From Iphone To Android
I’m trying to share my live location from my iPhone with a friend who only has an Android phone, and iMessage location sharing doesn’t work for them. What’s the easiest and most reliable way to send real-time location from iPhone to Android, preferably without making them install a bunch of different apps?
Had the same iPhone to Android location headache with my parents. Here is what works best in real life.
  1. Google Maps live location
    This is usually the easiest and most stable.
On your iPhone
• Install Google Maps from the App Store
• Sign in with a Google account
• Tap your profile picture top right
• Tap “Location sharing”
• Tap “Share location”
• Choose “Until you turn this off” or a time limit
• Pick your friend if they are in your Google contacts, or
• Tap “More options” and choose Messages, WhatsApp, etc to send a link
On their Android
• They open the link
• If they have Google Maps installed and are logged in, it shows you on the map
• If not, it still works in the browser, but the app is smoother
• Works iPhone to Android without iMessage
• Live, updates in real time
• You control when to stop sharing
• Needs data / internet
• Needs a Google account for best experience
  1. WhatsApp live location
    If both of you use WhatsApp, this is solid too.
On your iPhone
• Open WhatsApp, go to your chat with them
• Tap the “+” button
• Tap “Location”
• Tap “Share Live Location”
• Pick 15 min, 1 hour, or 8 hours
On their Android
• They open the chat and see your moving pin
• No extra setup if you already chat on WhatsApp
• End-to-end encrypted
• Both need WhatsApp
• Battery use is a bit higher
  1. One time pin drop via Apple Maps or Google Maps
    If you do not need live tracking, just send a static location.
Apple Maps
• Open Apple Maps
• Long press on your location
• Tap “Share”
• Send via SMS, WhatsApp, etc
Note, your friend might prefer to open it in Google Maps on Android
Google Maps
• Open Google Maps
• Tap your blue dot
• Tap “Share your location” or use “Share” from a pinned spot
• Send the link
What I use personally
• For trips with Android users, I stick to Google Maps live location
• For short meetups, WhatsApp live location is fast and simple
For your case, if you want easy and reliable, set up Google Maps on both sides and use Location Sharing. It works across iOS and Android without caring about iMessage at all.
Honestly, @jeff covered the “normal people” options really well, so I’ll throw in some alternatives and a slightly different angle instead of rehashing Google Maps and WhatsApp step-by-step.
If you want reliable more than pretty, a few other routes:
  1. Life360 (family / close friends vibe)
    If this is someone you share location with regularly (partner, family, roommate), Life360 actually works better than Google Maps for some folks:
  • Cross‑platform, so iPhone + Android is fine
  • Can auto‑refresh in the background more consistently
  • Lets you set “circles” so you don’t have to constantly re-send links
Downside:
  • You both need the app installed
  • It’s a bit “intense” for casual meetups, feels like you’re joining a family tracker cult
  1. Telegram live location
    If you already use Telegram, it’s a nice alternative to WhatsApp live location:
  • Open your chat
  • Hit the attachment icon, choose Location, then “Share my live location”
  • Same idea: 15 min / 1 hour / etc, shows you moving on their side
It’s cross‑platform and not tied to Apple or Google ecosystem. I’ve had it be more stable than WhatsApp in areas with spotty data, but that might just be my luck.
  1. Plain SMS link, but from something other than Apple Maps
    I kinda disagree with leaning on Apple Maps for sharing to Android. The link usually works, but Android users tend to have Google Maps as default and Apple Maps links sometimes act janky or open in the browser first.
    So if you want a simple “here’s where I am” with optional live tracking:
  • Use Google Maps on your iPhone to generate a share link
  • Paste it into plain SMS
    Your friend can open it in Google Maps on Android, which is what their phone actually wants anyway. This is less fiddly in real life than mixing Apple Maps with Android.
  1. For one‑off meetups where “live” is overkill
    Sometimes live location is just battery drain. If you’re just trying to meet at a cafe or venue:
  • Drop a pin in their preferred app (ask “you use Google Maps or something else?”)
  • Share that one static location
    Then if things change, send a new pin instead of streaming your location for an hour.
What I actually do:
  • Regular ongoing sharing with my partner on Android: Life360
  • Trips or group events with mixed iOS/Android: Google Maps live location like @jeff said
  • Random “I’m here, come find me”: one static Google Maps pin via SMS, no live sharing at all
If you just want “easiest, least annoying, keep working in the background,” I’d pick:
  • One‑time need: Google Maps link over SMS
  • Repeated / long term: Life360 or Google Maps permanent sharing
Also: whatever you choose, turn off Low Power Mode on your iPhone if you want stable live tracking. That thing quietly murders background location updates and makes it look like the app is broken when it’s really just iOS being “helpful.”
Skip the Apple vs Google drama for a second and think in tiers: “once,” “for this weekend,” and “forever.” Different tools shine in each tier, and this is where I disagree a bit with leaning too hard on stuff like Life360 for casual use.
1. One‑time or “just find me now”
If you literally just need them to walk to you, the lightest option is often best:
  • Open any map app on your iPhone that creates a regular web link (Google Maps is easiest here).
  • Drop a pin where you are and send that as a simple link by SMS or whatever chat app you both already use.
That avoids both of you installing new apps or managing permissions, and you’re not bleeding battery with live tracking. @jeff’s approach is basically the “normal people default” here and works fine in real life.
2. Short‑term live tracking for a trip / night out
Instead of going straight to a family‑tracker style tool, I like using a chat app that you already rely on for messaging, but not the ones already covered:
  • Signal live location:
    • Encrypted, cross‑platform.
    • Works nicely for a few hours while you are in transit.
    • You can set a duration and it expires automatically, so you do not forget to turn it off.
This keeps everything in one place: chat + location. Less mental load than juggling a separate “tracking” app if this is just for an evening.
3. Long‑term, ongoing sharing
If this is someone you regularly share with (partner, roommate, etc.), then a dedicated tracker actually starts to make sense. People already mentioned Life360, but I would think about any of these more as “always on infrastructure” rather than a one‑off solution.
Here is where something like “How To Share Location From iPhone To Android” guides and similar how‑to style products are oddly useful, because they walk non‑technical people through all the permissions and battery settings that actually determine whether these apps stay accurate in the background.
Pros of using a dedicated solution like that workflow or guide:
  • Puts everything in one clear setup flow instead of guessing through settings.
  • Typically explains background refresh, battery optimizations and privacy toggles step by step.
  • Easier to reuse later if you change phones or help family set it up.
  • Overkill if you just need a single meetup.
  • Adds one more “thing to follow” rather than simply installing an app and poking around.
  • Some guides are written once and never updated, so details can lag behind current iOS / Android versions.
4. Stuff people forget that actually matters
Whatever method you pick, a few boring details decide whether live location works or randomly freezes:
  • Turn off Low Power Mode on your iPhone while you share live location. Otherwise apps get throttled and look “buggy.”
  • On Android, your friend needs to disable battery optimization for whatever app you settle on, or their phone may stop updating your position in the background.
  • Double check both of you have solid data, not just “one bar of LTE pretending it works.”
Where I diverge a bit from @jeff and others
  • I do not like turning every casual meetup into a “we both install a tracking app” moment. For short, one‑off stuff, a static pin or temporary live location in a chat app is less socially weird.
  • I would avoid Apple Maps as the starting point whenever the recipient is on Android. It is not that it never works, it is that you are just introducing another potential failure step when Google Maps is what their phone already expects.
If you want a simple rule of thumb:
  • Meeting once: share a static Google Maps pin over SMS or your usual chat.
  • Following each other for an evening: use live location inside a chat app you both already use (Signal, Telegram, etc.).
  • Long term, repeated tracking: commit to a dedicated setup and follow a “How To Share Location From iPhone To Android” style walkthrough so both phones are tuned for background updates.
