How To Mirror Android To Tv
I’m trying to mirror my Android phone to my TV and I’m a bit lost on the best way to do it. My TV is a few years old and I’m not sure which casting or mirroring options it supports. I’ve tried a couple of apps and the built‑in cast feature, but either the TV doesn’t show up or the connection keeps dropping. Can someone explain the easiest reliable method to mirror an Android screen to a TV, and what settings or devices I should be checking?
First thing, figure out what your TV supports without guessing.
  1. Check for built‑in casting
  • On your TV remote, look for buttons or apps named:
    • Smart View
    • Screen Mirroring
    • Miracast
    • Cast
  • On your phone:
    • Open Quick Settings (swipe down)
    • Look for “Smart View”, “Screen Cast”, “Cast”, or “Screen Mirroring”
    • Turn Wi‑Fi on
    • Both phone and TV must be on the same Wi‑Fi network
    • Tap the cast option, wait a few seconds, pick your TV
If you see your TV name there and it connects, you are done. That uses Miracast or Chromecast built in, no extra apps needed. Third party apps from the Play Store often lag or have ads, so ignore those for now.
  1. If your TV does not show up
    Then it is likely too old or it is a basic non‑smart model.
Cheapest stable fix:
  • Buy a Chromecast with Google TV or a similar Android TV stick
  • Plug it into an HDMI port
  • Set the TV input to that HDMI
  • Set up Chromecast with the Google Home app
Then on your Android:
  • Tap “Cast” or “Screen Cast”
  • Pick the Chromecast device name
That gives you:
  • Full screen mirroring
  • Direct app casting from YouTube, Netflix, etc, which works better than full mirroring
  1. If Wi‑Fi is bad or laggy
  • Use 5 GHz Wi‑Fi if your router supports it
  • Keep phone and TV device in the same room as the router
  • Avoid streaming over mobile hotspot, that adds delay
  1. Wired option as backup
    Some Android phones support HDMI out with a USB‑C to HDMI adapter:
  • Check your phone model with a quick search like “ USB C HDMI output support”
  • If it supports it, get a USB‑C to HDMI adapter, plug into TV, then HDMI input
  • That gives lowest lag, good for games
  • Not all phones support this, so check first
  1. Stuff to avoid
  • Random “screen mirroring” apps from the Play Store that ask for weird permissions
  • Bluetooth only solutions, Bluetooth does not handle video mirroring well
  • Old DLNA apps, those usually stream files, not mirror the live screen
Quick path for you:
  • Try built‑in: phone Quick Settings > Cast > see if TV appears
  • If nothing appears, get a Chromecast or Fire TV Stick
  • Use Wi‑Fi, same network, and cast directly from system, not from third party apps
If you post your TV brand + model and your phone model, people here can tell you the exact method in like one line.
Couple things I’d add on top of what @cazadordeestrellas already covered:
  1. Double check what you actually need
    Mirroring and casting aren’t the same thing, and this trips a lot of people up:
    • Casting: Apps like YouTube, Netflix, Spotify send video directly to the TV / stick. Your phone becomes just a remote. Way smoother, less lag.
    • Mirroring: Literally streams your screen as a video feed. More lag, more compression, but works for stuff that doesn’t have cast support (games, random apps, browser, etc).
    If you mainly want YouTube / Netflix on the TV, you don’t need full mirroring. A cheap streaming stick and app casting is miles better than any mirroring app.
  2. Don’t rely on random Play Store mirroring apps
    You already noticed this:
    • They introduce delay
    • Spam ads or want weird permissions
    • Often use DLNA or browser tricks which are glitchy
      System level cast / Miracast / Chromecast is almost always more stable than a third party app. If you need an app to “fake” mirroring, your setup probably needs different hardware, not more software.
  3. Check if your “old” TV is secretly smart enough
    A lot of 4–7 year old TVs have:
    • Miracast / “Screen Mirroring” hidden in an Input or Network menu
    • “Anyview Cast”, “AllShare Cast”, or similarly stupid branded names
      Don’t just look for big icons. Go to:
    • Settings > Network / Connections
    • Inputs / Sources
      Sometimes it’s an input labeled like another HDMI and inside it there’s a Miracast screen waiting for a device.
  4. If you get audio but no video (or vice versa)
    This is a common “it half works” problem:
    • Make sure both devices are set to the same aspect ratio / resolution when possible
    • Turn off VPNs or “private DNS” on your phone temporarily
    • If you’re using Chromecast: turn off battery saver on your phone. Some phones aggressively throttle background casting and cause stutters or black screens.
  5. Fire TV Stick or Roku vs Chromecast
    @cazadordeestrellas mentioned Chromecast, which is great, but it’s not the only solid option:
    • Fire TV Stick:
      • Has its own “Display Mirroring” (Miracast style) for some Android phones
      • Plus app casting from YouTube, Prime, etc (though YouTube casting is a bit more roundabout sometimes)
    • Roku:
      • Supports screen mirroring on many Androids using Miracast
      • Also supports casting from certain apps
    If you mainly want general streaming, the exact brand doesn’t matter much. Pick the one that has the apps you use and then use mirroring only as a backup.
  6. When your Wi Fi sucks and you still want to mirror
    I’ll mildly disagree with the idea that “just use 5 GHz” magically fixes everything. It helps, but:
    • 5 GHz dies fast through walls
    • If your router is ancient, both 2.4 and 5 can be trash
      Extra trick:
    • Put the TV/streaming stick and your phone on a guest network or secondary SSID if you have one. Sometimes this isolates junk IoT devices and reduces congestion, making casting smoother.
  7. Weird but useful USB C cable trick
    If your phone supports wired video out and you don’t want to buy an HDMI adapter yet, some USB C hubs with HDMI that you might already own (for laptops) work too.
    • Plug phone into the hub
    • HDMI from hub to TV
      Not guaranteed, but if you already have a hub, it’s a free test before buying anything else.
  8. What I’d do in your situation
    Since you’re not sure what the TV supports and you already tried random apps:
    1. Check your phone’s Quick Settings > Cast / Smart View and see if anything appears that looks like your TV.
    2. Dig in your TV’s inputs and network menus for “Screen Mirroring” or Miracast. Turn it on explicitly. Try again from the phone.
    3. If nothing shows or it’s unstable, stop fighting it and just grab a Chromecast, Fire TV, or Roku. Use:
      • Casting from apps for most stuff
      • Screen mirroring only when you really need your whole screen.
If you drop your exact TV brand/model and phone model, folks can tell you in one line whether you’re stuck with a dongle or if there’s a hidden mirroring option buried three menus deep.
