Some websites on my iPhone keep telling me that JavaScript is disabled, and parts of the pages won’t load or work correctly. I’ve checked Safari settings but I’m not sure what I’m missing or if I need to change something in Screen Time or content restrictions. Can someone walk me through how to properly enable JavaScript on an iPhone so these sites function normally?
Short version. On iPhone you turn JavaScript on or off for Safari globally. There is no built in per site JavaScript toggle.
Still, here is what you can do and what to check.
Make sure JavaScript is on
- Open Settings app
- Scroll to Safari
- Tap Advanced at the bottom
- Turn JavaScript toggle ON
If it was off, most modern sites will break. That message you see fits that.
Check Content Blockers
These often block scripts for some sites and not others.- Settings
- Safari
- Content Blockers
- Temporarily turn them all off
Then reload the site. If it works, the blocker caused it. Go into the blocker app and whitelist that site.
Check “Hide IP Address” and privacy stuff
Some scripts fail when privacy add ons get too aggressive.- Settings
- Safari
- Under Privacy & Security try turning off
- Hide IP Address (for a test)
- Advanced → Feature Flags, make sure nothing odd is toggled
For iOS 17 and newer, try per site settings
This is not a direct JS toggle, but helps with scripts that need cookies or popups.- Open the problem site in Safari
- Tap the “aA” icon in the left of the address bar
- Tap Website Settings
- Make sure
- Use Content Blockers is OFF for that site
- Allow Pop-ups is ON if the site needs it
- Request Desktop Website is set how the site works best
Clear site data for stubborn sites
Sometimes old cache breaks script loading.- Settings
- Safari
- Advanced
- Website Data
- Search for the site
- Swipe left and Delete it
- Reopen Safari and try again
Test with another browser
Install Firefox or Chrome on your iPhone. Try the same site.- If it works there but not in Safari, the issue is Safari settings or content blockers.
- If it fails everywhere, the site has its own problem or blocks mobile.
To answer your main point. You cannot turn JavaScript on for one site and off for another with default iOS. It is either on for all or off for all. Per site behaviour usually comes from content blockers or security settings, so that is where you tweak things.
You’re not actually missing some secret “JavaScript per site” switch on iOS… because Apple just didn’t give us one.
@cacadordeestrelas already covered the global JS toggle and the obvious Safari / content blocker stuff, so I won’t rehash all that step‑by‑step. A few different angles you can try:
1. Double‑check: is it really JavaScript that’s “disabled”?
A lot of sites throw a super generic “JavaScript disabled” error when the real problem is:
- Certain scripts are blocked by:
- Tracking protection
- VPN / DNS filter (AdGuard, NextDNS, Pi‑hole, private relay, etc.)
- Corporate profiles / MDM on work phones
- Third‑party cookies blocked
- Cross‑site tracking disabled
Quick checks:
- Go to Safari settings
- Under “Privacy & Security” temporarily turn OFF:
- Prevent Cross‑Site Tracking
- Block All Cookies (if you had that on)
- Try the site again
If the site suddenly works, the message was basically “your privacy settings are too strong for our messy JavaScript ecosystem.”
2. Look for “weird stuff” outside Safari
Stuff that can silently kill scripts or requests:
- VPN / DNS blocking apps
Turn them off for a minute and reload the site. - Security / filtering apps (Norton, Kaspersky, AdGuard, etc.)
Many have their own per‑site blocklists that behave like a fake “JavaScript per site” toggle.
If the site only breaks when those are on, whitelist the domain in that app, not in Safari.
3. Use per‑site workarounds instead of per‑site JS
You can’t say “JS on for example.com, off for others” in Safari, but you can fake different behavior per site:
- On the site, tap
aAin the address bar → Website Settings:- Turn Use Content Blockers off just for that site
- Allow Pop‑ups if it relies on them
- This doesn’t flip JavaScript itself, but it often lets the needed scripts load.
This is where I slightly disagree with the idea that it’s “all or nothing in practice.” Technically yes for JS, but in day‑to‑day use, content blockers + per‑site settings do effectively act like a per‑site JS gate for many pages.
4. Compare Safari vs. another browser on the same engine
Install Chrome, Firefox, or Edge on your iPhone and test the same page. They all use WebKit under the hood, but:
- Each has its own UI, tracking protections, and integration with content blockers.
- If it works elsewhere but not Safari, it’s almost always:
- A Safari extension / content blocker
- Safari privacy settings
- Corrupted site data (cache / cookies)
If it fails in all browsers on your iPhone, the issue is probably your network, VPN, DNS, or the site itself being fussy with mobile.
5. Check for config profiles or “work phone” restrictions
If this is a company or school phone, IT can push a profile that:
- Forces specific content filters
- Blocks some scripts or domains
- Locks some Safari options
Go to Settings → General → VPN & Device Management and see if there’s a configuration profile. If there is, some restrictions may be out of your control. No setting in Safari will override that.
6. Reality check: per‑site JS is just not a thing on iOS
Right now, on iPhone:
- JavaScript is a single on/off toggle for Safari and WebKit browsers.
- Per‑site behavior is almost entirely driven by:
- Content blockers / filter lists
- Privacy & security settings
- VPN / DNS / security apps
- Site‑specific cache & cookie weirdness
If you want real per‑site JS control, the only honest answer is: you need a different platform or a jailbroken iPhone. On stock iOS, your best option is to tune blockers and privacy settings per site until those “JavaScript disabled” nag screens stop appearing.
You’re not missing a secret “per‑site JavaScript” switch on iOS; it really does not exist in Safari right now. @suenodelbosque and @cacadordeestrelas already nailed the global toggle and the usual Safari / content blocker suspects, so I will come at it from the angle of “why some sites complain and others don’t even when JS is on.”
1. Some sites lie about “JavaScript disabled”
Those banners are often a catch‑all error when any of their scripts fail, not only when JS is actually off. So even with JavaScript enabled globally, you can still see that message if:
- Their analytics or ad scripts are blocked
- Third party CDNs are blocked by DNS / VPN
- Cross site cookies or trackers are prevented from loading
So the message is sometimes really “our marketing stack is blocked” rather than “JavaScript is disabled.”
2. Hidden troublemakers outside Safari
Stuff that can silently break scripts, even if Safari looks fine:
- DNS filter / custom DNS: NextDNS, AdGuard DNS, CleanBrowsing, router level blocking, etc. These can kill script hosts like
cdn.something.com. - VPN or “secure browsing” apps: Security suites often inject their own traffic filters. Turn them off for a minute as a test.
- Apple’s iCloud Private Relay: Rare, but can confuse some badly written geo or anti bot scripts.
If a site only misbehaves on your Wi‑Fi but works on cellular, that screams DNS or router filter, not a Safari JavaScript problem.
3. Why some sites work fine while others complain
Because JavaScript on iOS is global, any real “JS off” situation would break every modern site. If only a few domains nag you:
- Those specific domains are more dependent on third party scripts (trackers, heavy ad networks).
- Your blocker / DNS / VPN is selectively blocking those third parties.
- So you effectively have “per site JS problems” even though the JS setting is all or nothing.
That is where I slightly disagree with the idea that content blockers just “act like JS switches.” In practice, they are usually only killing very specific resources, while the core JS engine stays fine. The site’s error page just isn’t smart enough to tell the difference.
4. A more systematic way to debug one stubborn site
Pick one problem site and try this sequence:
- Try it in Private Browsing in Safari. That uses a “cleaner” state: different cookies, more strict tracking protection. If it works there, your regular profile has some bad site data or cookies.
- On the problem page, tap
aA→ Turn off content blockers only for that site, leave everything else alone. Reload. If it starts working, you know the issue is blocker lists, not plain JavaScript. - If you use a DNS or VPN app, pause it for 30 seconds and reload. If that fixes it, whitelist the site’s domains in that tool.
You end up with a setup that is almost like per site JavaScript without actually touching the global toggle again.
5. If nothing fixes it, consider the site is just broken on iOS
Important reality check: some sites are simply coded poorly for mobile Safari. If:
- JavaScript is globally on
- Content blockers are off for that site
- No VPN / DNS filters are running
- Clearing that site’s data does nothing
and it still throws “JavaScript disabled,” the problem is probably on their side. Testing in another iOS browser (Chrome, Firefox, Edge) is a good control, but remember they all use the same WebKit engine underneath.
6. Why this is unsatisfying, but currently normal on iPhone
You basically get:
- One global JavaScript switch
- Per site workarounds through blockers, cookies, popups, and cache control
If you want real, granular “turn off JavaScript here, keep it on there,” you need a different platform or a jailbroken device. Stock iOS just does not expose that kind of control to users yet.
As for the empty product title you mentioned, pros and cons in this context would effectively be:
- Simplifies the experience so average users do not break the web by accident
- Keeps global behavior predictable across all sites
- No real per site JavaScript control on iPhone
- Power users cannot selectively harden or relax JS rules by domain
- Forces you to juggle content blockers and privacy toggles instead
Compared to the angles already covered by @suenodelbosque (clear, step based Safari fix list) and @cacadordeestrelas (deeper dive into privacy and external filters), the main takeaway here is: if only a handful of sites complain, treat it as a script or network filtering issue on those specific domains, not a missing Safari setting.
