How Can I Recover Data From Hard Drive With Bad Sectors At Home?
My hard drive started making strange noises and now parts of it won’t open because of bad sectors. It has important photos and work files I never backed up, and I’m hoping to recover the data at home before the drive gets worse. What steps or tools should I try to safely recover files from a hard drive with bad sectors?
Cyclic redundancy check errors are the kind of thing I stopped brushing off. Same with a system hanging while you open a folder. If the files matter, stop touching the drive.
If it’s an external drive, unplug it. If it’s your main internal drive, shut the machine down. I learned this the hard way a while back. Every extra boot kept the disk busy retrying bad spots, and the drive got worse before I even started recovery.
What these errors usually mean
There are two broad cases.
Soft bad sectors are the less ugly one. The drive surface might still be okay, but the data in a sector no longer matches the error checking info. I’ve seen this after a forced shutdown and after a power cut. Sometimes those sectors are recoverable.
Hard bad sectors are different. That points more toward physical damage. Bad platter area, weak head, failing hardware, stuff like tht. Software does not fix physical damage. At best, it helps the drive avoid those spots later.
The thing I would not do first
A lot of people jump straight to CHKDSK. I wouldn’t, not if your goal is file recovery.
CHKDSK tries to make the filesystem usable again. Its job is repair, not preservation. If filesystem entries are damaged, it might clean them up in a way that leaves you with fewer paths for recovery. I’ve seen cases where people ran it first and then had less to work with.
Safer move first, clone or image the drive
What worked better for me was making a full sector by sector copy before doing anything else. A clone or image gives you one controlled pass over the failing disk. After that, you work from the copy and leave the original off.
That matters because unstable drives don’t fail in a neat line. They drift. One hour they read 80 percent fine, later they choke on the same area.
A DIY route that makes more sense
If you want to try recovery yourself, use recovery software instead of repair tools. Disk Drill is one option. What stood out to me is how it handles weak drives during backup. It doesn’t sit there forever hammering one unreadable block. It skips rough areas, pulls easy data first, then circles back with smaller reads.
That behavior matters more than people think. Repeated reads on a sick drive are where things go sideways fast.
Practical order of operations
  1. Get another healthy drive with enough free space.
  2. Make a byte for byte image of the bad drive.
  3. Leave the original powered off after imaging.
  4. Scan the image for recoverable files.
  5. Save recovered files to a different third drive.
Don’t write recovered files back to the original drive. Don’t dump them onto the image destination either if you can avoid it. Keep your targets separate. Less mess, fewer mistakes.
When I’d stop the DIY attempt
If the drive clicks, grinds, beeps, refuses to spin, or stops being detected at all, I’d back off. Those signs usually mean mechanical trouble. Software won’t pull you out of that. Sometimes it pushes the drive closer to dead.
If the files are irreplaceable, go to a lab. Gillware and Techchef are two names people bring up a lot. They have the equipment for damaged hardware and clean handling.
It isn’t cheap. You might be looking at hundreds or a few thousand dollars. For family photos, business records, research data, stuff you can’t redo, I’d at least price it out.
What to do with the drive after recovery
Only after your files are copied and checked should you think about repairing the original disk. At that point, a full format or chkdsk /r is fine if you want to test it. Those steps mark bad sectors so the OS avoids them.
I still wouldn’t trust a drive like this for anything important again. Once it starts throwing CRC errors and freezing Explorer, I treat it like a spare at best, or e-waste if the symptoms keep growing.
The backup part people skip until it hurts
Set up backups after this. Seriously. The 3-2-1 rule is boring, but it saves your skin.
3 copies of your data.
2 different storage types.
1 copy off-site or in cloud storage.
That setup takes less time than one bad recovery weekend. I wish somebody had drilled tht into my head earlier.
If the drive is making strange noises, I’d be less optimistic about a full DIY save than @mikeappsreviewer. Bad sectors alone are one thing. Noise adds a higher chance of head or motor trouble. That matters.
My at-home approach would be smaller and faster.
First, stop opening random folders. Explorer freezes and retries are rough on a failing disk. If the drive still mounts, copy only the most irreplaceable files first, photos, docs, work stuff. Skip videos and large archives for now. Start with the folders you know matter. Time matters more than neatness.
Second, check SMART before doing long scans. Use CrystalDiskInfo or smartctl. If you see Reallocated Sectors, Pending Sectors, or Uncorrectable Sectors climbing, the drive is degrading in real time. If SMART shows bad health plus noise, I’d stop testing and move to recovery fast.
Third, keep the drive cool. Heat makes weak drives worse. I’ve had one limp along long enough to finish copying after putting a desk fan on it. Sounds dumb, worked anyway.
For software, Disk Drill is a solid pick if you want file recovery from damaged sectors without messing with the filesystem first. Its scan is easy to run at home, and it tends to be friendlier for non-tech people than a pile of command line tools. If you want to read user feedback first, check Disk Drill reviews and real user experiences.
One small disagreement with the clone-first advice. If the drive is noisy and fading fast, a full image attempt sometimes burns time you do not have. I’ve seen better results by grabbing the highest-value files first, then imaging what’s left if the disk stays alive. Not ideal, but real life isnt always ideal.
Do not run defrag. Do not install recovery software onto the bad drive. Do not keep rebooting.
If the sound is clicking, scraping, or spin-up spin-down, home recovery gets risky fast. At that point, a lab is the safer move. If it’s family photos or business files, that cost hurts less than permanent loss.
Strange noises changes the math. With just a few unreadable areas, home recovery is a maybe. With noise, it can turn into “one more power cycle and it’s done” real fast.
I mostly agree with @mikeappsreviewer and @codecrafter, but I’d add one thing: don’t get too hung up on a perfect plan. If the drive is still readable for short bursts, triage matters. Make a list of the exact folders that matter most and go after those first. Desktop, Documents, Pictures, project folders, exported invoices, whatever. Not your movie collection. Not Steam backups. Priorities.
Also, don’t test the disk to death. People love running every utility they can find because it feels productive. It isn’t. Surface tests, benchmark apps, repeated SMART refreshes, and “let me try opening that folder again” are all extra wear.
If you want to understand what a damaged storage area actually is, this is a decent plain-English explainer on hard drive bad sectors and unreadable disk areas.
One place I slightly disagree with @codecrafter: checking SMART is useful, but if the drive is audibly clicking or scraping, I wouldn’t spend much time reading diagnostics. The noise already told you enough.
My home-only play would be:
  • Connect it to the most stable machine you have
  • Disable sleep/hibernation so the copy job doesn’t get interrupted
  • Copy smallest, most valuable files first
  • Use a recovery app like Disk Drill if normal copying stalls or folders won’t open
  • Recover to a different healthy drive, never the failing one
If Disk Drill can see the partition or scan the disk image, that’s usually the least annoying route for photos/docs at home. If the drive starts disconnecting, vanishing from BIOS, or making louder noises, stop. That’s the point where DIY goes from “cheap” to “expensive mistake.”
And yeah, after this, retire the drive. A disk with growing bad sectors and weird sounds is not “still fine for secondary storage.” That’s people lying to themselfs.
I’d split this into two questions: can the drive still read anything, and is the noise electronic or mechanical?
Small disagreement with @codecrafter and @viajantedoceu here: if the noise is light buzzing but the drive stays mounted, I would try one controlled read session before spending time on diagnostics. Not scans, just targeted extraction. Sometimes you only get one decent window.
A couple of things nobody stressed enough:
  • Use a powered USB dock or a direct SATA connection if possible. Weak USB power can make a dying drive disconnect more often.
  • Turn off thumbnail previews in Windows Explorer. Broken video/photo files can trigger hangs just by browsing folders.
  • Copy by file type if folders freeze. Grab .docx, .xlsx, .jpg, .pdf first using search, instead of drilling into bad directories.
  • Avoid recovery on a laptop battery. Any sleep event or power dip is bad news.
About Disk Drill: decent choice for home use when normal copy fails.
  • simple interface
  • can recover from damaged partitions and bad sectors
  • good for photos, docs, common file types
  • less intimidating than many forensic tools
  • deep scans can take a long time
  • not magic for physically failing heads
  • recovered filenames/folder structure are not always perfect
  • best results usually need another healthy drive with lots of space
I agree with @mikeappsreviewer on one thing especially: do not repair first. Recovery first, cleanup later.
If the drive starts clicking in a steady pattern, disappears mid-copy, or slows to a crawl everywhere, stop DIY. That is the point where every extra minute can cost data.
