Choosing Between JavaScript and Python for My Next Project
I’m torn between using JavaScript or Python for a new web app and automation scripts. I know basic programming but not enough to judge which language fits better for performance, learning curve, job prospects, and long-term flexibility. Could experienced developers explain the real-world pros and cons of JavaScript vs Python and suggest which one I should prioritize learning first?
Short version. For your use case, start with Python, add JavaScript where the browser forces you to.
Breakdown by what you asked for.
  1. Web app
Frontend:
You must use JavaScript in the browser. Frameworks like React, Vue, Svelte all sit on JS. So no choice there.
Backend:
Python:
  • Fast to write. Django or FastAPI for APIs.
  • Good for automation, scripts, data work in the same language.
  • Lots of libs for HTTP, scraping, data, ML.
JavaScript / Node:
  • One language for frontend and backend.
  • Huge ecosystem on npm.
  • Great for real time stuff with websockets.
If you want fewer concepts to learn at once, do:
Frontend: JS
Backend: Python (Django or FastAPI)
This splits concerns and keeps each part clear.
  1. Automation scripts
Python wins here for most people.
  • Less boilerplate.
  • Simple standard library.
  • Strong libs: requests, selenium, playwright, pandas, etc.
  • Easy to read again in 6 months.
Node works, but you fight async patterns more, especially as a newer dev.
  1. Performance
For typical web apps and scripts, your bottleneck is:
  • Database
  • Network
  • Bad queries
  • Poor architecture
Not the language.
Node often handles lots of concurrent I/O well.
Python handles CPU heavy work well, especially when using C-backed libs like NumPy.
If you end up doing huge scale, you will profile and possibly mix languages anyway.
  1. Learning curve
Python:
  • Cleaner syntax.
  • Fewer surprises.
  • Good for scripting, automation, beginners.
JavaScript:
  • Has quirks, type coercion, this, async patterns.
  • Frontend requires you to learn DOM, bundlers, frameworks.
For your level, Python for logic and automation will feel simpler.
  1. Job prospects
Both are strong, depends on direction.
JavaScript:
  • Frontend, full stack roles.
  • React is everywhere.
  • Node for backend in a lot of startups.
Python:
  • Backend web.
  • Data engineering.
  • ML, AI, scripting roles.
  • DevOps tools often support Python.
If you want web UI focused roles, push harder on JS.
If you think about data, automation, backend, lean Python.
  1. Long term growth
Path 1, Python first:
  • Learn Python basics.
  • Build small CLI tools.
  • Write automation scripts.
  • Use Flask or FastAPI for APIs.
  • Add minimal JS in frontend to call your APIs.
Path 2, JS first:
  • Learn modern JS (ES6).
  • Make small browser apps.
  • Learn Node and Express.
  • Add scripting for simple file tasks.
For what you wrote, I would do:
Month 1–2:
  • Python basics, then requests, subprocess, pathlib.
  • Write 3–5 small automation scripts you actually use.
Month 3–4:
  • Learn FastAPI.
  • Build a simple API for your web app.
  • Minimal HTML + JS frontend that calls the API.
Month 5+:
  • Deepen JS on the frontend with React or another framework.
  • Keep using Python for backend and automation.
You get:
  • Productive scripts fast.
  • A real web app.
  • Both Python and JS skills for hiring managers.
If you share what your web app should do and what you want to automate, people here can suggest a stack that fits even tighter.
You’re not choosing “JavaScript vs Python,” you’re choosing “where do I want pain and where do I want speed.”
@caminantenocturno already laid out the sensible roadmap (Python backend + scripts, JS where the browser forces you). I mostly agree, but I’d tweak priorities a bit.
1. Start from what you actually care about
Ask yourself:
  • Do you enjoy messing with visuals, UI, buttons, layouts?
  • Or do you get more satisfaction from “this script ran and saved me 2 hours”?
If you lean UI:
  • You’ll eventually live more in JavaScript land.
  • Typescript + React on the frontend, Node on backend is a very common path.
If you lean automation / tooling / data:
  • Python is the comfy hoodie you’ll wear for years.
  • Web stuff becomes “wrap my Python logic in an API, sprinkle a tiny bit of JS on top.”
Your motivation will matter more than any theoretical performance difference.
2. On performance
Slight disagreement with @caminantenocturno: Node is not automatically better for concurrency in real life for beginners. People write blocking stuff in Node all the time and then wonder why everything crawls.
Python:
  • For scripts and “normal size” web apps, totally fine.
  • When performance does matter, you often lean on C-backed libs in Python, not rewrite in JS.
Node:
  • Can be very fast for I/O heavy apps.
  • But you pay a mental tax to juggle async everywhere.
If you’re not building Twitch 2.0 or a trading engine, this is all premature stress.
3. Learning curve trade‑off
I’d rank difficulty for a beginner doing what you want like this:
  • Python scripting: easiest
  • Python web backend (FastAPI / Flask): still friendly
  • JavaScript language itself: medium (quirks)
  • JavaScript in the browser: harder (DOM, bundlers, tooling, frameworks)
  • Node backend: comparable to Python web, but with more async overhead
So if your goal is “I want useful stuff running quickly,” Python gets you early wins. JS pays off more once you’re serious about frontends.
4. Job prospects angle
Brutal version:
  • If you want to be employable as “web dev”: ignoring JavaScript is not an option.
  • If you want to be employable as “automation / data / backend-ish”: ignoring Python is kinda shooting yourself in the foot.
So the realistic long term outcome is:
You will know both.
The question is just: which one becomes your “home base”?
  • Home base Python → better for:
    • automation, scraping, tooling
    • backend APIs
    • later, data / ML if you go there
  • Home base JS → better for:
    • front-end jobs
    • full stack startup roles
    • living in the browser ecosystem
5. Concrete recommendation for you specifically
Given:
  • basic programming skills
  • want a web app
  • want automation scripts
I’d flip the “full JS stack” hype and do:
  1. Pick Python as your main language for the next 6–9 months
    • Write all your automation in Python.
    • Learn how to package and schedule scripts.
    • Use requests, pathlib, maybe a bit of selenium or playwright if you need browser automation.
  2. Use Python for the backend of your web app
    • FastAPI if you like minimal & modern.
    • Django if you want batteries included and don’t mind heavier structure.
  3. Use the tiniest possible amount of JavaScript in the browser
    • Pure JS + fetch to call your Python API.
    • No big frontend framework until you feel the pain that justifies it.
Where I differ a bit from @caminantenocturno is timing:
They suggest ramping JS more aggressively in month 5+. I’d say you don’t have to unless your app really needs a rich frontend. A boring HTML + light JS frontend often ships faster and hurts your brain less.
6. Long term path
Once you’re comfortable:
  • If you like the web UI side:
    • Learn modern JS deeply.
    • Add React or similar.
    • Maybe learn Node so you can do full JS sometimes.
  • If you like automation / logic more:
    • Double down on Python ecosystems.
    • Treat JS as “browser glue” only.
You literally cannot “ruin” your future by choosing one first. For your mix of “web app + automation,” Python as the core language with JS sprinkled in is the path of least regret.
And yeah, ignore anyone who tells you you “must” go full JS stack right away. That’s just volunteering for extra confusion.
You’re not really choosing “JavaScript vs Python for everything,” you’re choosing “which one is primary for me right now, given this specific web app + automation combo.”
Let me zoom in on angles that weren’t covered as much by @shizuka and @caminantenocturno.
1. Think in projects, not languages
Instead of abstract “performance / jobs / learning curve,” take your actual plans:
  • Web app:
    • How interactive should the UI be?
      • Like a dashboard with live charts, drag & drop, inline editing?
      • Or mostly forms, tables, and some filtering?
  • Automation:
    • What exactly are you automating?
      • File tasks, backups, scraping, API calls, report generation?
If your web app is mostly CRUD + simple UI, then:
  • Python backend + light JS is enough and pleasant.
    If you want a really rich, app-like frontend:
  • JavaScript (ideally TypeScript) becomes more central.
This matters more than abstract benchmarks.
2. Where I mildly disagree with them
Both @shizuka and @caminantenocturno push Python-first, JS as needed. Sensible.
I’ll add a counterpoint:
If your long term goal is web dev employment in typical product companies, I’d seriously consider:
“JavaScript as primary, Python as tooling sidekick”
Why?
  • Almost every web team expects strong JavaScript on the frontend.
  • A lot of real-world work is wrestling with browser behavior, bundlers, and state management.
  • If you’re okay learning a bit more pain upfront, mastering JS + browser fundamentals early can pay off heavily.
So:
  • If your heart is set on shipping useful personal tools quickly → Python first.
  • If your heart is set on being very hireable as “web dev” specifically → prioritize JS a bit earlier than they suggest.
You will still use both eventually.
3. Performance without the fluff
For your scale, benchmarks are mostly noise, but the feel of performance tuning is different:
Python
  • Strong when:
    • You lean on libraries written in C (NumPy, Pandas, etc.).
    • You do data-heavy, CPU-ish tasks, but with library help.
  • Typical tuning knobs:
    • Database indices, queries
    • Caching (Redis)
    • Background workers (Celery, RQ)
Node / JavaScript
  • Strong when:
    • You have lots of concurrent I/O (many requests, websockets, streaming).
    • Making everything truly non-blocking
    • Scaling horizontally with many Node processes
In a “web app + automation scripts” context, 95% of your speed wins will come from:
  • Using a sane database schema.
  • Not doing useless work in loops.
  • Avoiding unnecessary network calls.
The language is not where you should spend decision energy.
4. Learning curve: what actually trips people
Some pitfalls not explicitly called out:
Python
  • People underestimate:
    • Virtual environments and dependency management.
    • Packaging scripts so they are runnable anywhere.
  • It feels super friendly, then you deploy and hit:
    • “Why does it work on my machine only?”
    • “Why is my cron job using the wrong Python version?”
JavaScript
  • Beyond the language quirks, the tooling stack can be brutal:
    • npm / yarn / pnpm
    • bundlers (Vite, Webpack, etc.)
    • frameworks (React / Vue / Svelte)
  • You can drown in choices and tutorials shouting about “best practices.”
So in terms of early friction:
  • Lowest friction to a useful script: Python.
  • Highest ceiling for complex UIs: JavaScript, but requires wading through more swamp up front.
5. Jobs & long term growth, but with actual tradeoffs
Both languages have excellent job prospects, but the shape of those jobs is different:
If you go Python-centric:
  • Strong directions:
    • Backend APIs (Django, FastAPI, Flask)
    • Data engineering / data science
    • Automation specialist or internal tools dev
  • Often closer to:
    • Infrastructure
    • Data teams
    • Internal platforms rather than shiny UIs
If you go JavaScript-centric:
    • Frontend / full stack web dev
    • SaaS product teams
    • Mobile via React Native or similar
  • Often closer to:
    • Product features
    • UX & design teams
    • User-facing stuff
There is no “better,” just: what do you want your day to look like?
  • Debugging layouts and user interactions → emphasize JS.
  • Gluing systems together and crunching data → emphasize Python.
6. Concrete decision patterns
Here are a few “if this, then that” patterns that might help:
  1. “I want to automate my life, write scripts, and build a basic web app to expose them.”
    → Python first, small JS where needed.
  2. “I want to become a front-end or full-stack dev at a product company.”
    → JavaScript first (and soon TypeScript), with Python later for scripting.
  3. “I’m not sure yet, I just know I enjoy making useful things and seeing them in a browser.”
    → Start Python for 2–3 months, then layer in JS more seriously. This matches what both @shizuka and @caminantenocturno suggested, and it is a low-regret path.
7. A slightly different roadmap
To complement their month-by-month plans, here’s a decision gate style roadmap:
  1. Phase 1: Scripts & tiny tools (4–6 weeks)
    • Use Python.
    • Automate something you do weekly.
    • Output to console, CSV, or simple HTML file.
    • If you hate Python’s feel here, that’s a huge signal.
  2. Gate 1: Did you enjoy Python scripting?
    • Yes → Keep Python as home base.
    • No → Switch early and commit to JavaScript/Node for scripting.
  3. Phase 2: Web exposure of your logic (4–8 weeks)
    • Wrap your script logic in:
      • FastAPI (Python) or
      • Express / similar (Node)
    • Build dumb but functional HTML forms to trigger actions.
    • Add the bare minimum JavaScript for async calls.
  4. Gate 2: What part felt most fun?
    • Styling UI / interactive bits → deepen JS & frontend.
    • API design / logic / data modeling → deepen Python backend & automation.
This way you let experience, not theory, choose for you.
8. On that empty product title: pros & cons
You mentioned the product title Choosing Between JavaScript and Python for My Next Project indirectly as the central topic. Treated as a sort of “guide” you might write or rely on, here are its pros and cons in your context:
Pros of “Choosing Between JavaScript and Python for My Next Project” style thinking:
  • Forces you to articulate:
    • requirements
    • constraints
    • personal preferences
  • Good for:
    • Searchability (“Choosing Between JavaScript and Python for My Next Project” is the exact phrase other people will Google)
    • Structuring your reasoning around performance, learning curve, jobs, long term fit
  • Encourages a false binary:
    • In reality you will probably end up mixing both.
  • Can delay starting:
    • You can overanalyze “best language” instead of just building the first version.
  • Ignores that:
    • Early projects are for learning as much as for shipping.
So treat that “Choosing Between JavaScript and Python for My Next Project” framing as a helpful mental checklist, not as a requirement to permanently marry one language.
9. How to actually decide this week
To avoid paralysis, pick one of these two experiments:
Option A: Python-first test
This week:
  • Write one useful automation script in Python.
  • Wrap it in a very small FastAPI or Flask app.
  • Add one HTML page with a bit of vanilla JS fetch to trigger it.
If by the end of that you feel “Whoa, this is enough for what I want,” lean Python-centric.
Option B: JS-first test
This week:
  • Build a simple browser-only app in JavaScript:
    • No backend, just local storage or mock data.
  • Make it have at least:
    • Dynamic UI updates
    • Some form handling
    • A bit of state and event handling
If you enjoy fighting the browser and love the interactive aspect, lean JS-centric and later add Python mostly for automation scripts.
Bottom line: there’s no fatal mistake here. For your combo of “web app + automation,” Python as core and JavaScript as browser glue is the lowest-friction route. If your long term ambition screams “web/front-end career,” then pay more attention to deep JS earlier than the others suggested, but still use Python aggressively where you want quick, readable automation.
