Can you help me with an honest Finch app review?
I’ve been using the Finch self-care app for a while and I’m not sure if I’m getting the full benefits out of it. Some features seem helpful, but others feel confusing or underwhelming. I’d really appreciate feedback from people who’ve used Finch longer than I have—what works, what doesn’t, and whether it’s truly worth sticking with or paying for premium so I can decide what to do next.
I’ve used Finch on and off for about a year. Here is what helped and what felt like fluff, so you can see if you are getting value.
  1. The “quests” and to‑dos
    • Good if you tie them to stuff you already need to do.
    • Add your real tasks, not vague self care prompts.
    • Keep it to 3 to 5 items per day so it does not turn into noise.
    • If you feel guilt when you miss tasks, turn off streak style thinking. Treat it like a checklist, not a grade.
  2. Reflections and breathing exercises
    • Helpful when you use them at a set time. For example, 5 minutes before sleep.
    • Pick 1 or 2 reflection types and stick with those. The huge list feels confusing and easy to skip.
    • If you already journal somewhere else, Finch reflections might be redundant.
  3. Pet growth and “energy”
    • Works as a light motivator if you like virtual pets.
    • If you tap through screens without thinking, it turns into clutter.
    • If the pet does not motivate you, ignore most cosmetic stuff. Treat the app like a planner with mood logs.
  4. Mood tracking
    • This part is underrated.
    • Use consistent tags for moods, like “work stress”, “sleep issues”, “social time”.
    • After 2 to 4 weeks, scroll through history and look for patterns. For example, worse mood on days with less sleep or no walk.
    • Without reviewing the data, mood tracking feels useless.
  5. Notifications
    • If you feel annoyed or overwhelmed, cut notifications to one or two key reminders.
    • Example: one morning prompt for tasks, one evening prompt for reflection.
    • Too many pings make you ignore the app.
  6. When Finch helps most
    • You like cute visual rewards and small goals.
    • You want light structure, not full therapy.
    • You need a low friction way to log mood and habits.
  7. When it feels underwhelming
    • You expect deep CBT style content or strong guidance. Finch content stays surface level.
    • You already use Notion, a planner, or another habit app. Finch can feel like a duplicate.
    • You feel pressure from streaks, tasks, or guilt when you miss days.
Quick way to test if you get the full value over the next 2 weeks
  1. Turn off all but 2 notifications.
  2. Set max 3 daily tasks, all tied to real life things.
  3. Do one short breathing or reflection exercise at the same time every day.
  4. Log mood once per day with tags.
  5. After 14 days, open stats and see if you notice clear patterns or small behavior shifts.
If you see patterns or feel slightly more organized or aware, the app works for you. If it still feels like tapping for cute animations, your time might be better in a simple notes app or habit tracker.
I’ve been using Finch for around 8 months and my take is a bit different from @byteguru in a few spots.
Where I agree:
It’s not a therapy replacement, and if you already live in Notion/Todoist/etc, Finch can feel like a cute skin on tools you already have. Also, the pet is only motivating if you’re actually into that kind of thing. If you feel nothing when the bird evolves, that whole loop is basically UI noise.
Where I disagree a bit:
  1. Surface level content isn’t always a problem
    I actually think the “shallow” nature of the exercises is a feature, not a bug, for some people. When I’m anxious or burned out, I’m not opening an app to do full CBT worksheets. Finch’s little prompts and mini-activities are like training wheels: just enough to get me to do something instead of doomscrolling. If you expect deep healing, yeah, it’s underwhelming. If you just need a gentle nudge, it’s fine.
  2. The variety can help, not just confuse
    The huge list of reflections can be overwhelming, but I found that rotating through a few kept me from getting bored. Using the same one every day started to feel robotic. So if you’re bored or skipping them, that might be why. Think “small menu” instead of “one item forever.”
  3. Pet mechanics as an emotion check
    This sounds silly, but the moments where I caught myself feeling annoyed at the pet animations were actually useful signals. If I’m too impatient to sit through a 2‑second animation, I’m usually restless or stressed IRL. So instead of treating the pet stuff as pure fluff, you can use your own reaction to it as a quick emotional mirror.
  4. Progress is subtle
    Where Finch quietly shines for me:
  • I’m more aware of “tiny wins” on crappy days.
  • I interrupt doomscrolling with a 1‑minute task instead of 40 minutes of social media.
  • I notice “I always log bad mood on Sundays” and adjust my weekends.
It’s not dramatic change, it’s tiny course corrections. If you’re expecting a total mental health overhaul, it will feel like a toy.
Red flags that it’s not doing much for you:
  • You only open it to tap stuff for the pet, not to actually think or log.
  • You feel more guilt than relief when you see tasks.
  • You never look at your past entries or stats.
  • You regularly think “I could have just done this in my phone’s Notes app.”
If that’s you, I’d say: Finch is probably acting as a distraction, not a tool. In that case, a simple habit tracker + a separate mood log might give you the same (or better) payoff with less clutter.
If you still want Finch to work, ask yourself two blunt questions:
  1. “Did this app help me make even one better choice this week?”
  2. “Do I feel calmer or more aware after using it, or just entertained?”
If you can’t honestly answer “yes” to at least the first one after a few weeks, it might not be you using Finch wrong. It might just not be the right app for how your brain likes to organize life.
Quick analytical take on Finch since you already got great nuance from @chasseurdetoiles and @byteguru.
I mostly agree with both of them, but I think they’re still evaluating Finch too much as a “tool” and not enough as an “environment.”
Where I see Finch actually working well
  1. Context shift instead of raw productivity
    The biggest win of the Finch self‑care app, in my experience, is that it creates a mental “bubble” separate from email, socials, and work apps. Even if the quests are simple, opening Finch instead of Instagram during a low moment is already a micro‑upgrade. That context switch alone is underrated.
  2. Good for people who struggle with “blank page” syndrome
    Unlike a plain notes app, Finch always has something for you to react to: a prompt, a quick activity, a nudge. If you freeze when a blank journal shows up, this structure can be more useful than a customizable planner.
  3. Safety net for low‑energy days
    I disagree slightly with @byteguru on “add only real‑life tasks.” For some people, that turns Finch into yet another productivity tracker. On bad days, logging “drink water” or “get out of bed by 11” might actually be the point, even if it looks trivial on paper.
  4. Gentle emotional pacing
    @chasseurdetoiles mentioned subtle progress, and I’d push that further. Finch is strongest when you use it as a brake, not a gas pedal. If it slows you down just enough to ask “how am I doing right now” three times a week, that’s a useful role that a lot of heavier tools do not fill.
Where Finch tends to flop
  1. Too many interaction layers
    Tapping through energy screens, pet actions, menus, etc can become friction instead of motivation. If it takes 8 taps to log “tired,” some people just stop. Simpler mood apps like Daylio or Reflectly do this part cleaner.
  2. Weak for people who like deep frameworks
    If you are the kind of person who loves detailed CBT workbooks, habit stacking frameworks, or Notion dashboards, Finch’s content will probably feel like shallow, non‑configurable widgets. In that case, tools like Stoic, Fabulous, or plain Notion + a habit app can feel more aligned.
  3. Progress is hard to see at a glance
    The data is there, but not surfaced aggressively enough. If you are data‑motivated, you may feel underfed compared to more analytics‑oriented tools like Habitica, Routinery, or Streaks.
How to decide if Finch is actually doing something for you, without repeating their methods
Skip changing your setup for now. For the next 7 days, just observe:
  1. Track your urge to open it, not just usage
    When you feel stressed, bored, or lonely, do you ever want to open Finch instead of scrolling or gaming? If the answer is “never,” the app probably is not wired into your coping patterns and may not be worth the headspace.
  2. Notice after‑effects within 15 minutes
    Each time you use Finch, ask yourself:
    • In the next 15 minutes, did my behavior shift even a little?
    • Did I choose water over soda, step outside, send a text, or go to bed earlier?
      If Finch sessions rarely change your next 15 minutes, it is mostly entertainment.
  3. Check “emotional friction”
    Do you feel dread or relief when you think of opening Finch?
    • If dread or guilt is the default, it is functioning as yet another obligation.
    • If mild relief shows up, the system is at least not harming your mental load.
  4. Compare to a zero‑app baseline
    For a couple of days, do not open Finch at all. Do not replace it with another app. Just live normally. Then reintroduce Finch and notice:
    • Are you slightly more reflective, or basically the same person plus extra taps?
      This comparison is harsher and more honest than looking at in‑app streaks.
Where I differ slightly from both
  • They focus on optimizing how to use Finch. I think it is equally valid to decide intentionally that Finch is “just a cozy toy” in your ecosystem. If the pet and tiny prompts keep you from spiraling for 5 minutes, that is enough, even if you never mine the mood stats.
  • They both lean on mood‑pattern analysis. Useful, yes, but not mandatory. If that level of reflection overwhelms you, it is fine to treat Finch as a present‑moment tool and ignore long‑term trends.
TL;DR decision rubric
Keep the Finch self‑care app if, after a couple of weeks:
  • You instinctively open it instead of doomscrolling at least once or twice a week.
  • It leaves you feeling slightly more grounded, not graded.
  • Even the “fluffy” parts make you pause and breathe, rather than rush.
Consider switching to a simpler competitor (basic habit tracker + mood app like Daylio, or a planner plus something like Stoic) if:
  • You mostly tap through screens without reflection.
  • You feel more pressure than comfort.
  • You would not miss it if it disappeared from your phone tomorrow.
That framing should show you whether you are missing hidden value or whether Finch simply does not match how your brain likes to care for itself.
