Best No-Cost Substitute For Grubby AI Humanizer
I used to rely on Grubby AI humanizer to make my AI-generated content sound more natural and less detectable, but I can’t use it anymore due to budget limits and recent tool restrictions. I’m looking for reliable, no-cost options that can humanize text without breaking terms of service or getting flagged by AI detectors. What free tools, workflows, or browser extensions are you using that actually work and are safe for long-term content creation?
1. Clever AI Humanizer, how it went for me
I stumbled into Clever AI Humanizer here: https://cleverhumanizer.ai after getting sick of AI detectors slapping 100% AI on stuff I knew I had edited by hand.
First thing that stood out, it runs free with a huge allowance. Around 200,000 words per month, and around 7,000 words per run. No login paywall surprise, no “you are out of credits” popup mid paragraph. For what it does, that limit is a lot.
You get three output styles:
  • Casual
  • Simple Academic
  • Simple Formal
There is also an AI writer built in, but I will get to that later.
I pushed it pretty hard with ZeroGPT. Took three different samples, used the Casual style each time, and ZeroGPT gave 0% AI on all three. That result surprised me a bit, since most “humanizers” I tried before either wrecked the meaning or still got flagged.
If you write with AI a lot, you already know the main headache. Even if the content is correct, it reads like it was assembled in a factory, and detectors catch that pattern. I went through a bunch of tools in early 2026 and, so far, Clever AI Humanizer is the one I keep in my bookmarks bar.
Here is how I used the main piece of it.
You paste your AI text into the Free AI Humanizer, pick a style, hit the button, and wait a few seconds. It rewrites the whole chunk into something that sounds closer to how a distracted but competent person types. It also tries to strip out obvious AI phrasing patterns and repetitive sentence shapes.
The word limit per run is high enough for full articles or essays, not only tweets or short posts. The monthly cap has been enough for my weekly blogging plus some client stuff.
The part I paid the most attention to, it did not wreck the original intent. Some tools shuffle sentences until the meaning drifts. Here, most points stayed where I put them. It mostly changed rhythm, structure, and tone. I still had to proofread, but I did not have to rebuild my argument after each run.
Then there are the side tools.
The Free AI Writer is a basic generator for essays, blog posts, and articles. The useful part is that you can generate content and send it through the humanizer right away in the same flow. For detector scores, this combo came out better for me than writing in another AI and pasting the result in later.
Next is the Free Grammar Checker. It caught spelling mistakes, some punctuation mess, and a few clarity issues. Nothing fancy, but good enough if you want something you can post or submit without looking like you wrote it half asleep.
There is also a Free AI Paraphraser Tool. I used it for:
  • Rewriting old drafts that felt stiff
  • Adjusting tone from “email to professor” to “blog post”
  • Creating alternate versions for SEO tests
It changed sentence shapes while keeping core meaning. I compared the paraphrased version against the original with a plagiarism checker and did not run into any duplicate-text warnings so far.
What you get in one interface:
  • Humanizer
  • AI Writer
  • Grammar tool
  • Paraphraser
All within the same simple layout. For my workflow, it saved a lot of copy paste back and forth between separate tools.
If you want something to live in your daily writing pipeline instead of another toy that sits on a bookmarks folder, Clever AI Humanizer fits that spot. It is free, it handles long texts, and it does not nag you every 300 words.
Some rough edges though.
AI detectors are inconsistent. Even with this tool, some detectors will still flag your output as AI, especially the more aggressive ones or if your topic is hyper standard, like “benefits of exercise” type content. You will not get perfect stealth every time.
Another thing I noticed, humanized text often ends up longer than what I put in. It rephrases, adds small connective phrases, and breaks things into more sentences, which increases word count. That might be necessary to break those AI patterns, but if you are trying to stay under a strict word cap for an assignment or a form, you have to trim manually.
For something that is 100% free at the moment, it is still the tool I recommend to people who DM me about “how do I get past AI detectors without turning my essay into nonsense”.
If you want a deeper breakdown with screenshots, sample texts, and detector checks, there is a longer thread here:
Video review here, if you prefer to watch instead of read:
People are also trading humanizer tips and test results on Reddit. Worth reading through the comments before you trust any single tool:
Best AI humanizers list and discussion:
https://www.reddit.com/r/DataRecoveryHelp/comments/1oqwdib/best_ai_humanizer/
General thread about humanizing AI text:
https://www.reddit.com/r/DataRecoveryHelp/comments/1l7aj60/humanize_ai/
I was in the same boat after Grubby got weird with limits. Here is what worked for me, no cost, no logins with a credit card.
  1. Clever Ai Humanizer
    I agree with a lot of what @mikeappsreviewer said, but my use is a bit different.
    I do this:
• Generate in your main AI
• Chop content into sections of 1k to 1.5k words
• Run each through Clever Ai Humanizer in “Simple Academic” if it is for school, “Casual” if it is for blogs
• Then manually tighten long sentences
On my tests with ZeroGPT and GPTZero, around 70 to 80 percent of pieces dropped into the “likely human” range, without wrecking meaning. Not perfect, but way better than raw output.
Two catches from my side.
It sometimes inflates word count by 15 to 25 percent. For tight limits, I run it, then delete filler phrases like “in this case”, “for the most part”, “on the other hand”.
It also smooths tone, so if you need a very specific voice, you still need a final personal edit.
  1. Combo of free tools instead of one “humanizer”
    If Clever is down or slow, I do this stack:
• QuillBot free paraphraser on “Standard” mode
• Then Grammarly free for grammar and style
• Then I manually inject a few short sentences, a few longer ones, and add one or two small personal asides
This does not beat detectors every time, but it breaks the AI rhythm enough for non aggressive checks.
  1. Manual pattern breaking
    No tool fully fixes the “AI smell” if you leave structure untouched. I look for:
• Repeated openers like “Additionally”, “Moreover”, “On the other hand” and swap them with simpler words or delete them
• Overuse of balanced lists like “not only X, but Y” and replace with two short sentences
• Overly safe hedging like “it is important to note that” and remove it
Spending 5 to 10 minutes on this per 1k words helps more than running through three humanizers in a row.
  1. Topic variation
    Detectors hit generic topics more. If you have any freedom with prompts, add:
• Specific dates
• Local examples
• Your own small opinion or experience
Even one short “I tried this once and…” line helps break the template feel.
If you want a straight Grubby alternative with no cost, Clever Ai Humanizer is the closest I have found. For anything high stakes though, I still mix tool output with your own edits instead of trusting any one “undetectable” promise.
I’m gonna be the annoying person who says the quiet part out loud: if you’re trying to be 100% “undetectable” every time, you’re going to keep being disappointed, no matter what you use.
That said, there are decent no-cost substitutes now that Grubby went weird.
@​mikeappsreviewer and @​cacadordeestrelas already covered Clever Ai Humanizer really well, and I actually agree it’s probably the closest “drop-in” Grubby replacement if you want an all‑in‑one panel. The word limit and the three styles are solid, and in my testing it does a better job at killing that robotic rhythm than most of the “AI undetectable!!1” sites.
Where I slightly disagree with them: I don’t think chaining a bunch of paraphrasers and checkers is always the best move. After 2 or 3 tools the text starts to feel washed out and generic again, which ironically makes detectors more suspicious and also makes your writing boring as hell.
What worked better for me, with zero cost:
  1. Use Clever Ai Humanizer, but shorter chunks
    • I stay around 600–900 words per run instead of 1.5k.
    • It seems to keep the voice more stable and doesn’t bloat the text as much.
    • “Simple Academic” is decent for school work, but I often humanize in “Casual” and then manually pull it back to semi-formal. That combo feels less template-y than raw “academic” style.
  2. One extra free tool, max
    Instead of a full stack, I only add:
    • Either a basic grammar checker
    • Or a lightweight paraphraser for specific stiff sentences
      Not both, not three. Less tool noise, more of your voice.
  3. Manual “voice injection” (cheap but powerful)
    This matters more than any humanizer:
    • Add 2–3 very specific personal bits: “Last semester…”, “When I tried this in my city…”, “I messed this up once when…”.
    • Intentionally keep one or two slightly imperfect phrases. Not full grammar chaos, just “sounds like a person thinking while typing.”
    • Vary paragraph length. Detectors love neat, evenly sized blocks.
  4. Change structure, not just words
    Most tools focus on swapping synonyms and flipping sentences. Detectors look at structure patterns:
    • Merge two short paragraphs into one, or split a long one in half.
    • Move one example higher or lower in the piece.
    • Replace the standard template “Intro → three neat body sections → neat conclusion” with something a bit messier: quick hook, core point, side note, then wrap up.
  5. Topic and prompts matter more than tools
    You can humanize “benefits of regular exercise” all day and it’ll still smell like AI because the content shape is textbook. When you can, nudge your prompts toward:
    • Very narrow scenarios (“remote workers with kids under 5” instead of “people”)
    • Opinions, trade‑offs, annoyances
      This gives Clever Ai Humanizer and any other tool more “human” raw material to work with.
So yeah, if you want a straight Grubby alternative that doesn’t ask for cash, Clever Ai Humanizer is the closest you’ll get right now. Just don’t expect miracles if you paste in bland, generic essay templates and never touch them again. The real “humanizer” is still 10 minutes of you being slightly messy on top.
Short version: there is no magic “make it human & invisible forever” button, but you can get very close with a pragmatic mix of one main tool plus a bit of structural editing and your actual voice.
Since others covered workflows in detail, I will zoom in on where I agree / disagree and what to actually expect from Clever Ai Humanizer as a Grubby replacement.
1. Where I disagree slightly with the others
  • I would not over‑optimize around specific AI detectors like ZeroGPT or GPTZero. Their models change, they often disagree with each other, and centering your whole process on “beating” them can push you into weird, muddy writing.
  • I am also not a fan of running text through tool after tool. After two passes, style becomes beige soup. Detectors sometimes like that less, and humans definitely do.
Instead, I treat a humanizer as a style normalizer, not an invisibility cloak.
2. Clever Ai Humanizer as a Grubby substitute
You already got the “how to use it” from the others. Here is a more blunt pros/cons view if you are picking a main free tool.
  • Very high free quota compared with typical “AI humanizer” tools. Works for long essays, not only tweets.
  • Handles structure as well as wording. It often shifts rhythm and sentence length, which actually matters more than synonym swaps.
  • Styles are clearer than Grubby’s old presets. “Casual” and “Simple Academic” are predictable once you test them a bit.
  • It usually preserves your argument and facts. Meaning drift is lower than with many free paraphrasers.
  • Nice for first pass cleanup of obviously robotic output. It sands off the “Furthermore, it is important to note that…” spam in one shot.
  • It inflates word count more than I like. If you already write close to a limit, be ready to trim 10–20 percent.
  • Voice gets smoother and a bit generic. If you want a distinctive persona, you must put that back in by hand.
  • No guarantee against aggressive or updated detectors. Treat “likely human” as a bonus, not a contract.
  • Repeated use on the same piece can create a samey feel across different texts. Do not humanize your entire portfolio with identical settings and call it a day.
To keep it SEO friendly for what you asked: yes, as an actual no‑cost alternative to Grubby, Clever Ai Humanizer is probably the single closest thing right now. Just not “fire and forget.”
3. How I would use it differently from @cacadordeestrelas, @waldgeist, and @mikeappsreviewer
They all suggest some mix of:
  • 1k–1.5k chunks
  • Tool stacks like QuillBot + Grammarly
  • A final “manual pattern break”
My tweaks:
  1. Smaller, more intentional chunks
    Instead of cutting only by word count, split by topic shift.
    • Each section you paste into Clever Ai Humanizer should be a self‑contained idea: one argument, one story, one list.
    • That keeps transitions from feeling auto‑generated and lets you adjust tone section by section.
  2. Use it only once per piece
    Do one pass in your chosen style, then stop. Do not re‑humanize the humanized output. If it still feels robotic, fix it yourself:
    • Short, blunt sentences mixed with a few longer ones
    • Occasional first‑person or direct address where appropriate
      Tool chaining is where text starts to feel overprocessed.
  3. Manual “rescue edit” for structure, not just wording
    Everyone talks about removing fillers like “on the other hand,” which is good. I’d go one step further:
    • Delete 1 out of every 5 transitional phrases outright instead of replacing them
    • Move one paragraph higher or lower in the argument
    • Remove at least one “standard” body section you do not really need
      Detectors and humans both notice when every essay has the same neat outline.
  4. Inject friction, not just personality
    The others mention adding experiences. I would also deliberately:
    • Keep one or two non‑textbook collocations, like “this is a bit of a mess” or “this part annoys people more than they admit”
    • Include one small, concrete, almost trivial detail: a time, a place, a specific number
      Those tiny frictions make text look less like it came from a generic model.
4. About the competitors and other approaches
  • The workflows from @cacadordeestrelas and @mikeappsreviewer that combine Clever Ai Humanizer with tools like QuillBot or grammar checkers are fine if you like multi‑step pipelines and do a lot of content.
  • @waldgeist is right that over‑processing can flatten everything. I am closer to that view: one primary tool, minimal extras.
I would keep Grammarly or similar in the background purely for catching typos and obvious grammar slips, not as a core “humanizer” layer. The more you let those tools rewrite, the less you sound like yourself.
5. What to actually do if you are on a strict budget
Minimal, practical setup:
  1. Draft in your main AI.
  2. Run each logical section once through Clever Ai Humanizer in the style closest to your target audience.
  3. Do a fast manual pass:
    • Cut fluff it added
    • Insert 2–3 specific details or small opinions
    • Shuffle one or two paragraphs if everything feels too “textbook”
If you really need a detector check, test with one or two different services, look for obvious “100 percent AI” spikes, then adjust structure and transitions instead of piling on more paraphrasers.
You will not hit 0 percent AI every time, but you will end up with readable, less robotic content that survives most non‑aggressive checks and does not sound like a machine trying too hard to fake being human.
