Where Is Trash On IPhone For Messages With Attachments?
I deleted some iPhone text messages that had photos and other attachments, but I can’t find a Trash folder in the Messages app. I’m trying to figure out where deleted messages with attachments go and whether there’s any way to recover them before they’re permanently removed.
If your iPhone storage barely changes after deleting a bunch of stuff, the deleted files probably haven’t actually been removed yet. On iOS, a lot of apps keep deleted items in a Recently Deleted folder for about 30 days, so they still take up space until you clear them for real.
Check the hidden trash folders first
Files app
Open Files, go to Browse, then keep tapping the back arrow in the upper left until you’re at the main Browse screen. Under Locations, look for Recently Deleted with the trash icon. Open it, tap the three dots, choose Select, then Delete All. This one can get surprisingly large if you download PDFs, videos, work docs, ZIPs, or other big files.
Photos
Open Photos, go to Albums, then scroll down to Utilities and open Recently Deleted. If there’s anything you still need, recover it first. Otherwise tap Select, then Delete All. Until you do this, those photos and videos are still counted against your storage.
Messages
This is the one a lot of people miss. Deleted text threads can keep their attachments around, including photos and videos. Open Messages, tap Edit or the filter icon in the top left, then choose Show Recently Deleted. Delete the conversations again from there if you’re sure you don’t need them.
Notes
Go back to the main folder list in Notes and open Recently Deleted. It works the same way, with deleted notes hanging around for roughly 30 days unless you remove them manually.
One thing to be careful about: if iCloud is turned on, permanently deleting something from Recently Deleted can remove it from iCloud and your other Apple devices too. Check the folder before you hit Delete All, especially in Photos where you can see how many days are left before each item expires.
Why the phone feels bad when storage is full
iOS needs some free space for temp files, app data, background tasks, and normal system stuff. When the phone is nearly full, it can get weird fast: camera lag, apps crashing, slow app switching, downloads failing, that kind of thing. Emptying Recently Deleted helps, but it only clears things you already deleted.
The bigger problem is usually the photo library itself.
After that, deal with the large media files
Clever Cleaner is useful for the part that’s annoying to do manually. It’s free, has no ads, and doesn’t require a subscription.
  1. Start with the Heavies tab. It sorts files from biggest to smallest and shows the exact size, so old 4K videos and huge screen recordings are easy to spot.
  2. Then check Similars. It groups near-duplicate photos and picks a Best Shot, which makes it easier to clear out five versions of the same picture.
  3. Look at Screenshots too. It shows the file size for each one, and screenshots pile up faster than people realize.
  4. The cleanup runs on the device, so your photos and data are not uploaded somewhere else.
The order that usually makes the storage bar finally move is: clear Recently Deleted in Files, Photos, Messages, and Notes first. Then use Clever Cleaner to find the large videos, screenshots, and duplicate-looking photos that the regular iPhone cleanup doesn’t catch.
Messages doesn’t have a separate trash can for attachments. Mike’s path is right for deleted conversations, but the photos/videos attached to those texts come back or disappear with the message thread, unless you saved them to Photos or Files, in which case they have their own Recently Deleted area.
Deleting a whole conversation is different from deleting an attachment out of an existing conversation. If you deleted the thread/message, check Messages > Edit or Filters > Show Recently Deleted. Restoring it should bring the photos and attachments back with that message, assuming they are still within the recovery window.
If you removed an attachment from inside the thread, or deleted it through iPhone Storage > Messages > Review Large Attachments, don’t expect a separate “Trash for attachments.” Apple doesn’t really give you an attachment recycle bin there. At that point your realistic options are a backup from before the deletion, another Apple device that has not synced the deletion yet, or asking the other person to resend it.
The other confusing part is saved copies. If you tapped Save on a photo from Messages, that copy lives in Photos and has its own Recently Deleted album. Same with something saved to Files. But the copy that only existed inside the text thread follows the Messages recovery rules, not the Photos or Files trash rules. So I’d check Messages Recently Deleted first, then Photos/Files only for anything you intentionally saved.
