I’m experimenting with AI writing tools and want to create sexy, adult-themed prompts that stay respectful, consensual, and within content guidelines. I’m struggling to find the right balance between sensual storytelling and what’s allowed on most platforms. Can anyone share tips, frameworks, or examples for writing tasteful sexy AI prompts that won’t get flagged or banned?
Short version. You want: sensual, adult, respectful, safe for guidelines.
Here is a practical way to do it.
Set boundaries in the prompt
Start with a line like:
“Write a sensual, adult story focused on emotion, attraction, and consensual intimacy. Avoid explicit anatomical detail, graphic descriptions, or pornographic language.”
That tells the model where the line is. -
Use “fade to black” for explicit parts
Example prompt chunk:
“Stop before explicit description. When the scene turns sexual, focus on their feelings, tension, anticipation, and cut away with a fade to black.”
Then in-story:
“He kissed her, slow and deliberate, and the rest of the night blurred as they disappeared into the bedroom.”
That keeps it sexy without graphic stuff. -
Focus on senses, not body parts
Instead of “graphically describing body parts,” nudge the model to describe:
• Touch: warmth, pressure, closeness
• Sound: breaths, whispers, tone
• Smell: perfume, sweat, environment
• Mood: nervous, needy, bold, shyExample:
“Describe how the air feels between them, the way their bodies react, and how their thoughts race, rather than explicit actions.” -
Keep consent front and center
Put this straight in the prompt:
“Both characters are adults. They communicate clearly. They respect boundaries. Consent is explicit and continuous.”
Then cue moments like:
“Show them asking, checking in, pausing if something feels off.” -
Use softer vocabulary
In your prompt, ask for:
“Use sensual, suggestive language, not graphic or porn style words. Focus on romance and tension.”
Terms like “they explored each other” or “their bodies moved together” keep things suggestive but not explicit. -
Style templates you can reuse
a) Flirty tension, no on-page sex
“Two adults flirt all evening. The story builds tension through close proximity, lingering looks, and playful banter. End when they close the door to the bedroom, without describing what happens next.”b) Aftercare focused
“Write a short scene that takes place after they slept together, with no details of the act. Focus on cuddling, conversation, teasing, and emotional connection while they lie in bed.”c) Slow burn
“Write a slow-burn scene with a near-kiss. They want each other, but they stop before anything explicit. Focus on frustration, attraction, thoughts, and body language.” -
Test your lines
Write a short paragraph, run it, then dial it back if it feels too explicit.
Example revision path:
• Too explicit: “He grabbed her…”
• Softer: “He pulled her close…”
• Softer again: “He stepped in, close enough that she felt his breath on her neck.” -
Watch common red flags
Avoid in your prompts:
• Age ambiguity. Always say “two adults” or “both are in their late twenties” etc.
• Power imbalance with no consent or negotiation.
• Violence or humiliation for arousal.Put a line like:
“Exclude minors, non-consent, coercion, humiliation, or degrading content.” -
Example full prompt you tweak each time
“Write a sensual short scene between two adult characters in their thirties. They have known each other for a long time and feel strong mutual attraction. Focus on flirting, emotional tension, physical closeness, and the way they touch each other in a suggestive but non-graphic way. Use soft, romantic language, avoid explicit anatomical terms or pornographic description. Show clear, enthusiastic consent and respect for boundaries. When the encounter becomes sexual, keep it implied and focus on their feelings and thoughts rather than explicit acts. End with a tasteful fade to black.”
If the model still pulls too tame, nudge it with:
“Push the sensual tension and steaminess as far as possible while still staying non-graphic and respectful.”
That gives it permission to be spicy but keeps you inside guidelines.
I like a lot of what @himmelsjager laid out, but I think if you lean too hard on safety language in the prompt, the model sometimes gets scared and writes like a PG Hallmark movie. You can keep it within guidelines without sounding like a legal contract.
What’s worked for me:
- Start with vibe, not rules
Instead of leading with “avoid explicit anatomical detail, no pornography, no X, no Y,” I start with:
“Tone: steamy, intimate, romantic, adult, focused on desire and emotional vulnerability.”
Then I add a brief safety line later:
“Keep descriptions suggestive rather than graphic and avoid explicit sexual detail.”
The model defaults to the tone you describe up top.
- Use relationship context as your throttle
If you say:
- “Longtime friends finally giving in to their attraction” = slow, emotional, more focus on feelings.
- “Two adults with established physical chemistry, already lovers” = you can push a bit more heat while still non‑graphic.
So your prompt could be:
“Two adults who are already lovers share an intensely intimate evening. Focus on their anticipation, teasing, the electric physical closeness, and the relief of finally being alone together, while keeping any sexual activity implied rather than described in detail.”
- “Camera placement” trick
Instead of “fade to black” (which is great but can end scenes too early), I specify where the camera is:
- “Keep the narrative camera at the level of faces, hands, and overall body language, not specific explicit actions.”
- “If things escalate, focus on reactions, breath, and emotion while keeping the physical details offstage.”
That lets the scene continue, just not visually explicit.
- Let the model know how far is ‘too far’ with examples
You can give negative examples without being graphic:
“Avoid play‑by‑play descriptions of sexual acts. Do not describe specific positions or detailed contact between genitals. Instead, describe how their bodies respond and how the moment feels to them.”
That’s different from just “no pornographic language,” which is a bit vague.
- Anchor in inner monologue
To keep things steamy but guideline‑safe, load the prompt with this:
“Spend a lot of time in their thoughts: nerves, arousal, little flashes of jealousy or insecurity, how badly they want each other, their attempts to keep control.”
When the character is thinking about how much they want to touch the other person, you can convey a ton of heat without ever describing the actual touch in explicit terms.
- Calibrate after first draft
I usually do this loop:
Prompt:
“Make it as sensual and intense as possible while still being non‑explicit.”
Then when the model gives a scene that’s too tame or too hot, follow with:
- “Second draft: keep the same scene, increase the tension and physicality by 20%, but do not add graphic sexual detail.”
or - “Second draft: keep the same scene, reduce any borderline explicit content by 20%, keep the emotional and sensual intensity.”
You’re basically turning a “heat dial” without asking for explicit stuff.
- Structure trick: 3‑phase scene
You can literally format the request like:
“Write a scene in three phases:
- Build-up: lingering touches, flirty remarks, noticing each other’s bodies in tasteful ways.
- Threshold: the first real kiss, their decision to go further, explicit consent.
- Implied intimacy: keep it suggestive and mostly off-page, focus on sounds, fragmented thoughts, and cut away before anything graphic.”
This gives the model a shape, which keeps it from going full mushy fade‑out at the first kiss.
- Watch the word choice, not just content
Even when staying safe, words can feel clinical or porny. You can say in the prompt:
“Use tender, emotionally charged language, avoid clinical terms and crude slang. Use words like ‘warmth, closeness, shiver, pulse, ache’ and avoid naming body parts explicitly.”
Basically give it a mini word‑palette.
Example full-ish prompt tying it together:
“Write a steamy but non‑explicit scene between two adults in their late twenties who have been quietly in love for years and are finally alone together. Tone: intimate, romantic, charged with desire. Focus on their inner thoughts, emotional vulnerability, and how their bodies react to each other’s closeness, breath, and touch, without describing explicit sexual acts or naming genitals. Keep the narrative camera on their faces, hands, and overall body language. Use soft, suggestive wording rather than graphic detail. Show clear, enthusiastic consent in dialogue or actions. Let the scene build through flirting, then a first intense kiss, then implied intimacy, cutting away before any explicit description.”
From there, just tweak knobs: “more playful,” “more angsty,” “shorter scene,” “only the build‑up, no implied sex,” etc. After a couple passes you’ll find a balance that feels sexy to you but still lives well inside the content rules.
A simpler method is the “two-pass rewrite.”
First, write a normal romantic scene with clear consent and no sexual instructions. Focus on dialogue, setting, and emotional stakes.
Second, ask the tool:
“Rewrite this scene with stronger sensual tension. Preserve every event. Add closer proximity, interrupted speech, lingering eye contact, nervous gestures, and mutual desire. Keep intamacy implied. Avoid explicit anatomy or sexual acts.”
This approach seperates plot from heat. You control the content before adding sensuality, so the tool has less room to drift. If needed, request one focused change per revision, such as more teasing or more tenderness.
Skip the temptation to stack every safety phrase and every heat trick into one mega-prompt. When you cram ‘enthusiastic consent, adults, no genitals, fade to black, but also as steamy as possible’ into a single block, a lot of models read the contradiction and just freeze up or hand you something flat. Pick two or three levers, not eight.
The bigger thing nobody here mentioned is that the tool matters more than the wording. Same prompt that @andarilhonoturno posted will run clean on one writing assistant and bounce with a policy warning on another, because ‘within content guidelines’ isn’t one standard, it’s whatever platform you’re on. So before you spend an hour tuning phrasing, find out where the wall actually is for your specific tool. Some allow implied intimacy no problem. Some flag anything past a kiss no matter how tasteful you keep it. That’s a five minute test, and it saves you from blaming your prompt for a limit that’s baked into the service.
On the two-pass idea from @binaryfox_56, I’d say that’s the most reliable one in the thread, but watch the second pass. When you ask it to ‘add sensual tension’ to an existing scene, models tend to escalate on every rerun, so by draft three you’re further than you wanted and didn’t notice. Lock the scene events, change one dial per pass, and reread the whole thing cold instead of just the new bits. That drift is the part people forget.
