Looking For Tips On How To Recover Files From A Corrupted USB Stick
My USB stick suddenly stopped opening after I unplugged it, and now it says the drive is corrupted. It has important photos and work documents I didn’t back up, so I really need advice on safe USB data recovery methods or tools that might help me recover files from a corrupted flash drive without making things worse.
USB corruption comes from a bunch of different failure types, so I would not jump straight into repair tools and hope for the best. I’d check what kind of mess I’m dealing with first.
A few quick checks gave me the clearest picture when I had this happen:
  1. Does the USB show up in Disk Management?
  2. Is the reported size correct?
  3. Does Windows label it as RAW?
  4. Do you get a format prompt?
  5. Does another PC see it?
  6. Does it disconnect on its own, lag hard, or slow to a crawl?
Those details matter more than people think. If the drive appears in Disk Management and the capacity looks right, I’d say your odds for home recovery are still decent. If it keeps dropping connection, never shows up, gets hot, or the connector looks beat up, I’d start suspecting hardware trouble.
If the system still detects the stick, I would pull data off first and mess with repairs later. I learned this the hard way once. Corruption is often a symptom, not the root issue. A bad repair attempt on a weak USB can leave you with less than you started with.
For this kind of case, I’d reach for Disk Drill.
What I liked about it was simple. It does not depend only on the file system being readable. Even when Windows refused to open a damaged USB for me, the software still scanned the device itself and pieced files back together from raw data. It also recognized a lot of file types, kept folder structure better than some other tools I tried, and let me preview files before saving them. That preview step saved me time.
The part I would not skip is Byte-to-Byte Backup.
On a shaky drive, I do not like scanning the original media first. I’d make a full sector image and work from that copy. It gives you a frozen snapshot of the USB at its current condition. If the stick gets worse later, your image is still there, which matters a lot when the device is acting flaky.
The process I’d follow looks like this:
  1. Install Disk Drill on your PC.
  2. Plug in the USB drive.
  3. Open Disk Drill and pick Byte-to-Byte Backup.
  4. Create a full image of the USB and save it somewhere else, not on the same drive.
  5. Mount or attach the image in Disk Drill.
  6. Scan the image, not the USB.
  7. Preview what it finds.
  8. Recover the files you need to a different storage device.
I’d only start trying to fix the USB after the files are safe.
Depending on what you saw earlier, the next step might be one of these:
  1. Run CHKDSK.
  2. Assign a new drive letter.
  3. Reinstall USB drivers.
  4. Use Windows Error Checking.
  5. Do a full reformat.
I’d stop doing DIY stuff and look at a recovery service if the drive is not detected at all, shows physical damage, holds work files you cannot replace, or starts disconnecting while you’re trying to recover data. I’ve seen people keep pushing in those situations and end up worse off.
Also, I would not trust the USB again by default after recovery. If corruption showed up for no clear reason, came back after formatting, or the drive kept acting weird in normal use, I’d replace it. Flash drives wear out. Some limp along for a while. Some don’t. Once one starts acting suspicious, I’m done with it.
Stop plugging it in and out. Every reconnect is extra stress on a failing stick.
I agree with @mikeappsreviewer on one big point, recover first, repair later. Where I differ is CHKDSK. I would not run it early on a USB with photos and docs you care about. CHKDSK is for fixing file system issues, not for preserving damaged data. I’ve seen it turn file names into junk and dump stuff into FOUND.000. Fine for a throwaway drive, bad move for irreplaceable files.
What I’d do:
  1. Try a different USB port, same computer.
  2. Try another computer, no format, no repair prompts.
  3. If it opens even once, copy the most important folders first.
  4. If it does not open, use recovery software before any fix attempts.
Disk Drill is a solid pick here because it scans the USB as storage, not only as a normal readable drive. For corrupted USB data recovery, start with the free scan and preview. If your files show up with proper previews, your odds are decent. Recover to your PC or another drive, not back to the USB. Obvious, but ppl still do it.
One more thing people skip, check Device Manager. If the stick appears with errors, uninstall the device and reconnect. Sometimes Windows gets dumb after an unsafe unplug.
If the drive disconnects, gets hot, reports 0 bytes, or vanishes mid-scan, stop. That points more to hardware failure than file system corruption.
If you want a quick visual walkthrough, this USB data recovery video guide for corrupted drives is easy to follow.
Before you do anything else, stop plugging/unplugging it over and over. That’s how a 'maybe recoverable' USB turns into a tiny plastic brick. I mostly agree with @mikeappsreviewer and @sterrenkijker on the big idea: recover first, repair later. Where I differ a bit is the 'try every basic Windows fix' approach. If the files actually matter, I would avoid stuff like Properties > Tools repair, auto-fix prompts, and especially formatting 'just to see if it works.' Windows loves offering 'help' at the worst possible time. What I’d add: - Check if the USB is visible in Disk Management as a full disk, not just a drive letter. - If Linux is available, try a live USB session and see if it mounts read-only there. Sometimes Linux reads a damaged stick that Windows refuses to touch. - If the files are super important, do not browse the USB in File Explorer repeatedly. Every failed read can stress a dying flash drive. Also, if this is a cheap no-name USB, be a little skeptical. A lot of those fail at the controller level, and software recovery gets real sketchy real fast. If it still shows the correct size and stays connected, I’d use Disk Drill for USB data recovery, but only to scan and recover files to another drive. If possible, image/backup the stick first, then work from the copy. That part matters more than ppl think. If the drive shows 0 bytes, disappears, gets hot, or freezes your system, stop DIY. That’s lab territory. For anyone researching safe file recovery from a damaged flash drive, this thread on how to recover files from a faulty USB drive safely is worth reading too. And yeah, after recovery, retire that stick. Trusting it again is kinda asking for round 2.
