My iPhone keeps saying storage is full, but I’ve already deleted photos, apps, messages, and downloads. The storage bar still shows a lot of space used, and I can’t figure out what’s taking it up. I need help finding hidden iPhone storage, system data, or cached files so I can free up space without resetting everything.
Yeah, this is insanely annoying. I had almost the same thing happen on my 14 Pro about a month ago. I deleted a ton of stuff, something like 2,000 photos and around 50 long videos, then went back into Settings expecting a bunch of free space. The storage bar basically looked the same.
A couple things are usually going on here.
First, the iPhone Storage screen in Settings is slow to update. It does not always recalculate right after you delete things. Sometimes it is just showing old cached storage info. If you have not already done it, shut the phone all the way off, wait a minute, then turn it back on. I have had to restart more than once before iOS finally showed the correct number.
The bigger thing, though, is Recently Deleted. Deleting photos or videos does not actually free the space right away. They sit in Photos for 30 days unless you clear them manually. Go to Photos, then Albums, then scroll down to Recently Deleted, and hit Delete All. If you deleted 5GB of videos and they are still sitting there, your used storage is not really going to change.
Also check whether you have Optimize iPhone Storage turned on. If you do, your phone may only be storing smaller local versions of your photos while the full-size files are in iCloud. So deleting a bunch of photos might barely move the storage bar because the local files were already tiny.
When my storage was stuck near full, the phone felt awful too. Swiping lagged, apps took forever to open, and it even restarted on its own a couple times. iOS needs some empty space for temporary files and normal system stuff. Once there is basically no breathing room, the whole phone can start acting old.
The built-in storage screen was not very helpful for me because it mostly showed broad categories. I ended up trying a few cleanup tools, and the one that actually helped was Clever Cleaner. I’m normally suspicious of cleaner apps since a lot of them are ad-filled subscription traps, but this one was free, with no ads or paywall.
The useful part for me was the Heavies section. It sorted my photo library by file size, largest first. That’s how I found a few huge 4K screen recordings I had completely forgotten about, around 4GB each. I never would have found those just scrolling through the camera roll. It also has a Similars section that groups near-duplicate photos and lets you keep the best one while deleting the rest.
I also liked that it works on the phone instead of uploading your photos somewhere else to scan them. After clearing the big videos and a bunch of duplicate screenshots, I got about 15GB back and the lag pretty much disappeared.
If your storage still looks full after all of that, check System Data, which used to show up as Other. That can be app caches from Safari, TikTok, Instagram, and similar apps. Safari cache can be cleared in Settings. For social apps, sometimes the easiest fix is offloading or deleting and reinstalling the app, since they can build up a ridiculous amount of cached data.
If nothing works, then you may be dealing with stuck “ghost” files. At that point the annoying fix is backing up to iCloud, doing Erase All Content and Settings, then restoring from the backup. It is a hassle, but it can clear out junk the system refuses to release any other way.
I’d start with Recently Deleted and a full restart, then look for giant videos or screen recordings. There is a good chance one or two huge files are causing most of the problem.
Check Settings > General > iPhone Storage and tap the biggest apps instead of trusting the color bar at the top. A lot of “mystery” space is really inside apps you still have, especially Podcasts, Music, Netflix/YouTube downloads, Maps offline areas, Mail attachments, or Files saved under “On My iPhone.” Deleting the app icon is not the same as clearing downloads inside the app, and offloading keeps documents/data in some cases. I agree with the restart/Recently Deleted advice, but if the bar still barely moves, look for apps where “Documents & Data” is larger than the app itself. That usually points straight at the culprit.
The exact number next to System Data matters more than the colored storage bar here. If that section is huge, deleting photos and apps may not change much because the space is being held by iOS caches, failed update files, logs, or sync junk rather than normal files you can see.
Check Settings > General > iPhone Storage and scroll down for an iOS update file. If there is one sitting there, delete it and restart. A half-downloaded update can take several GB and people miss it because it does not look like an app. I’d also leave the phone plugged in, on Wi-Fi, and locked for a while after deleting stuff. iPhones sometimes do cleanup later, especially if iCloud Photos, Messages in iCloud, or Files/iCloud Drive are still syncing.
I agree with @suenodelbosque that app data is usually the better place to look than the bar. But I would not expect any cleaner app to fix System Data directly. Something like Clever Cleaner is useful if your Photos library is still the problem, especially for spotting huge videos or duplicates, but it will not magically remove iOS cache. If System Data stays massive after a restart, deleting any pending update, clearing Safari history/data, and reinstalling cache-heavy apps, the clean backup-and-restore route is probably the real fix. Annoying, but sometimes that is the only way to make iOS let go of stuck storage.
Clearing Recently Deleted will not help much if the space is being held by a stalled sync or backup, not by normal photos anymore.
Before you wipe the phone, check the status messages inside Photos and iCloud. Open Photos, go to Library, scroll all the way to the bottom, and see if it says anything like syncing paused, restoring from iCloud, uploading, or not enough storage. If iCloud Photos is stuck, the phone can sit in a weird state where deleted items, thumbnails, originals, and database files are still being juggled around. Same idea with Messages in iCloud. It may look like you deleted the content, but iOS has not finished reconciling it yet.
I slightly disagree with jumping straight to erase and restore unless you have confirmed a current backup first. If the phone is nearly full, backups and updates can fail halfway, which makes the whole thing more stressful. If you have access to a Mac or Windows PC, plug the iPhone in and check it through Finder or Apple Devices/iTunes. Sometimes doing the iOS update from the computer frees the phone from needing a huge temporary update file on the phone itself, and it can force a more accurate storage readout afterward.
A quick triage method is this: go to iPhone Storage, ignore the colored bar, and look at the actual list. If the biggest number is Photos, use Photos or something like Clever Cleaner to find large videos and duplicates. If the biggest number is an app’s Documents & Data, delete and reinstall that app only after making sure its data is backed up. If the biggest number is System Data and it stays huge after a restart, a full charge on Wi-Fi overnight, and any pending update removed, then you are probably dealing with iOS cache or stuck files.
Do not forget the boring stuff either: Mail attachments, voice memos, GarageBand projects, downloaded language files, offline maps, and old device backups in iCloud settings can be easy to miss. The storage page is annoying because “nothing left to delete” usually means “nothing obvious left to delete,” not that the phone is actually empty.
