Can CHKDSK Fix The Parameter Is Incorrect On An External Hard Drive, Or Will It Make Things Worse?
My external hard drive suddenly shows “The parameter is incorrect” when I try to open it in Windows. I’m worried about losing files and not sure if running CHKDSK will repair the drive or make data recovery harder. Has anyone fixed this error safely?
Don’t format the drive just because Windows tells you to. That’s the big thing. The 'The parameter is incorrect.' message can look scary, but it doesn’t always mean the drive is dead or the files are gone. A lot of the time Windows just can’t read the file system correctly.
I’d also be careful with CHKDSK at the start. It can help later, but I wouldn’t run it before copying off anything you care about. If the drive is failing or the file system is badly damaged, repairs can sometimes make recovery harder.
Start with the boring checks first, because they’re quick and sometimes that really is all it is:
  1. Use a different USB cable.
  2. Try another USB port, ideally one directly on the motherboard if this is a desktop.
  3. Plug the drive into another computer.
  4. Check Disk Management and see if the drive shows up with the right capacity.
If Disk Management still sees the drive and the size looks correct, that’s a better sign. It usually means Windows can still talk to the device, even if it can’t mount the file system properly.
Next, check the drive health before you put more stress on it. CrystalDiskInfo is good for this, and Disk Drill also has SMART monitoring if you already have it installed. If you see warnings about reallocated sectors, pending sectors, or anything that looks like a serious SMART problem, stop using the drive as much as you can. Every scan or repair attempt means more reads from a drive that may already be unstable.
For getting the files back, I’d use Disk Drill. That’s what saved my files when this happened to me.
The part I liked most was Byte-to-byte Backup. Instead of repeatedly scanning the original drive, it makes a full image of it first. Then you scan the image, not the physical drive. That’s a much safer approach if the drive might be failing, because you’re not hammering the original device over and over.
Once you have the image, or if the drive seems healthy enough to scan directly, run a Universal Scan. After the scan finishes, preview the files before recovering them. Photos, documents, videos, whatever matters to you. If the previews open normally, that’s usually a good sign. Just don’t recover the files back onto the bad drive. Use a different disk.
Only after the important stuff is copied somewhere safe would I start trying repairs.
What to try depends on what you’re seeing:
  1. If Windows still recognizes the file system, you can try CHKDSK with chkdsk X: /r to fix logical errors.
  2. If the , CHKDSK usually isn’t useful. In that case, TestDisk may be worth a shot since it can often rebuild damaged partition information.
  3. If the issue seems to be Windows rather than the drive, run SFC and DISM to repair system files.
  4. There are also some weird cases where changing the Windows decimal separator back to a period fixes the error. Not common, but it does happen.
If you’ve recovered your files and none of the repair options help, I’d do a quick format. If the drive works normally after that, it was probably file system corruption. If the same error returns after formatting, I wouldn’t trust the drive anymore.
There’s also a point where DIY stops being a good idea. If the drive clicks, drops out randomly, vanishes from Disk Management, shows up inconsistently, or SMART reports serious errors, unplug it and stop testing. That’s when a recovery lab has a much better chance than home software.
Most labs will evaluate the drive first and quote you before doing the actual recovery. A lot of them also have a no data, no fee policy. Logical recovery is often somewhere around $300-600. If the drive needs hardware repair or clean-room work, it can easily be more like $700-2,000+, depending on the damage and capacity.
https://www.youtube.com/watch?v=_e4D_2bu8LE
Don’t run CHKDSK just to “see what happens,” because it is not a harmless scanner once repair flags are used. It can rename, delete, or relink file system records, which may make the drive mount again but leave recovered files messier.
If the files matter, image or copy what you can first, then repair the original only after you have another copy.
If the drive is making odd noises or disconnecting, CHKDSK is the wrong first move. In that case the problem may be hardware, and CHKDSK can sit there hammering the same bad areas for hours while trying to “fix” a file system that is only broken because the disk can’t be read reliably.
Where I’d push back a little is on treating chkdsk X: /r as the normal next repair step. /r is much more aggressive and slow because it checks for bad sectors too. If the drive is healthy and you already have a backup, fine. If you do not have a copy of the files yet, I would avoid both /f and /r. CHKDSK does not know which files are important to you. It only cares about making the file system consistent, and sometimes that means dumping things into FOUND.000 or cutting loose damaged directory entries.
A quick sanity check I’d do before any repair is to see whether the problem follows the drive or follows Windows. Try another PC, but do not click format if prompted. If another machine reads it, copy the files immediately. If no machine reads it but the capacity is correct, clone/image it first and scan the clone with recovery software. Disk Drill, DMDE, R-Studio, PhotoRec, whatever you are comfortable with. The brand matters less than the order of operations: recover first, repair later.
After your files are safe, CHKDSK is fair game. At that point the worst case is mostly wasted time or a drive you end up formatting anyway, not losing the only readable copy of your data.
The file system type matters here, because CHKDSK is not equally useful in every “parameter is incorrect” case. If Disk Management shows the partition as RAW, unallocated, or the capacity looks wrong, CHKDSK is mostly a dead end and may just add more stress. If it still shows NTFS or exFAT with the correct size, then CHKDSK has a better chance of fixing a logical file system problem, but I still would not make it the first write operation on a drive with files you need.
A safer middle step is running plain chkdsk X: with no /f or /r. That should only report what it sees, not repair it. It is not risk-free if the disk is physically failing, since it still reads the drive, but it is very different from telling Windows to start modifying file system records. If the output says there are errors and the drive sounds normal, stays connected, and SMART looks clean, then you can decide whether the data is worth recovering first or whether you are comfortable trying repairs.
The bit people forget is that “fixed” and “recovered my folder structure perfectly” are not the same thing. CHKDSK can make a volume mount again while leaving you with missing names, orphaned files, or stuff in FOUND.000. That is why I’d treat it as a repair tool after backup, not a recovery tool before backup. If you cannot copy files normally, image the disk first with whatever tool you trust, then scan the image with recovery software such as Disk Drill, DMDE, R-Studio, etc. Once the files are somewhere else, run CHKDSK, format, experiment, whatever. At that point you are repairing a drive, not gambling with the only copy.
